beta for CS4 causing issues with dv files in Premiere
I have opened a trouble ticket for this but I thought I would also ask here to see if anyone else is seeing this.
I am running Vista ULtimate 64bit.....clean install with Adobe CS3 & CS4 Production suites. I have been running the latest version of Prospect inside of CS3 and largely ignoring CS4 for a while. I had some DV footage supplied by a client and was in the midst of editing it when I installed CS4 beta prospect software. Initially I tested extensively inside of CS4 playing around with HD clips and all was ok. I assumed that CS3 would stay mostly unchanged. But when I went back to work on my DV project in CS3 it just crashes each time I load it. I rebooted, used the shift key trick, nothing would allow my almost finshed 1 hour long dv project to load. So I removed the Cineform folder from CS3 plugins and now my project loads fine. I restored the entire folder but left out the file that is the CFHD_IMporter (not exact name) and it still works. Then I restored that and it starts crashing again. So I tried a fresh project in DV and the minute I import any DV .avi file, Premiere CS3 crashes. If I remove the CIneform importer file, DV files import fine again. And to be clear it is not just on import. If I open a project that already has a DV file anywhere in it, Premiere crashes too. So....... I am wondering if this is happeneing to anyone else. I realize that most of us edit HD now, that is part of the reason we are so gung-ho for CIneform. But surely this behavior is not by design. Anyone else seeing this? Can anyone try to see if this is happening to them also? I sure hope this is not yet another obscure weird glitch that only affects me and cannot be recreated. I seem to have a thing for those pesky things. Thanks. |
