Neo Scene renaming
Does anyone know if there is a way for Neo Scene to convert footage without adding the triple digit number at the end of the name of the newly converted clip?
Where it says "Base Capture Name" in preferences I tried blanking it out, and it worked once, but only once. For subsequent sessions it has reverted to adding the digits even though I check preferences and re-blanked it out. |
Thanks Keith, I appreciate it!
Oooops, it is still doing it. I had that box unchecked already, as I thought, but made sure, and darn that is aggravating.
Destinatin folder is the same...I've tried it literally about a dozen times, probably many more since last night and the result is the same. I always go to preferences first to make sure...I've tried using same folder for destination and different one.
that sounds like something is glitching. I believe it is designed to work the way I've described it. Maybe try uninstall/reinstalling it?? It might be a good idea to deactivate it before you uninstall it.
by the way, there's another similar tickbox option in the prefs but I think it's only related to capturing/converting hdv streams. |
I think it is a glitch too, thanks.
| All times are GMT -6. The time now is 11:37 PM. |
