-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Can not render Cineform AVI files, Please help! (https://www.dvinfo.net/forum/cineform-software-showcase/234333-can-not-render-cineform-avi-files-please-help.html)
Chris Wysocki April 30th, 2009 06:24 AM
Ive contacted cineform to help me resolve this issue. Jake has been helpfully trying to get me back on track but no luck so far. Hopefully anyone else has any good ideas.
I got so fetup with my rig, so i reinstalled everything!
I reinstalled vista 64bit ultimate.
reinstalled vegas 8.0c
reinstalled latest neo hdv
and still can not render a 5 min. project using cineform codec
Is there something im doing wrong or thats not enabled? This is so weird , i never had a problem.
3.6 ghz intel quad core and 6 gig of ddr2 800 ram and this should render in like no time. Last night i started rendering at 8 p.m. and woke up this morning and it was at 66 percent only. And froze. Other times it would reach around 30 percent.
Can you guys help me , please. I choose render as --AVI -- HDV1080i60 --- best quality --- cineform codec 4.3.4 something (cant remember the exact number here , im at work ) --- decode , encode rec709 ---- high hd--- framerate auto
ohh , if i unclick the use opendml it renders sooo fast but freezes around 2 gig. But it renders sooooo fast. Should i try installing a trial version of neo scene and see if i can render? should i put XP on ? Im out of ideas and i need to get my project done.
Thanks , Chris
David Newman April 30th, 2009 09:11 AM
Neo HDV is old now. Try Neo Scene or Neo HD v4.
Chris Wysocki April 30th, 2009 09:19 AM
I know its old but it still does everything i need. Im gonna try the trial neo scene and see if that works.
Chris Wysocki May 9th, 2009 04:23 AM
Still trying to figure this out , :(
Ok , so i tried many new thing with out luck. I dont think its a software problem though i could be wrong. I tried installing XP,vegas, neo hdv and no luck.
Neo Scene trial didnt work either. I took xp off and went back to vista ultimate. I have my OS and programs on a raptor drive and i have all my media video files on two 1 Tarabye drives mirrored. the are the same make and model and new had a problem before. I reformated both drives and put the media back on and then defraged them with no luck again.
Tonight im going to try setting it to use one thread only. Im outta ideas , I tried rendering them to other hd codecs that vegas offers with the same result , So it cant be cineform.
Chris Wysocki May 10th, 2009 05:07 PM
I got it working. I had to switch from 4 threads to 1. What does that mean? Does my Core 2 Quad 9650 not have enough power to do 4 threads? I didnt have a problem running 4 threads with a core 2 duo. What gives?
Jay Bloomfield May 10th, 2009 05:58 PM
Before you waste too much time on this, Vegas Pro 9 comes out this week. There are a lot of problems with Vegas 8 when using more than two cores. Some people can make it work like a charm and others just tear their hair out trying to make it work.
Sony Creative Software - Online Store - Upgrade to Vegas Pro 9 from Vegas
The upgrade price is listed as $234.95, but there is an additional $50 discount, if you order before June 30, 2009. You also get your choice of additional free Sony software:
Sony Creative Software - Forums - Vegas Pro - Video Messages
Cineform is planning on supporting Vegas Pro 9 64 bit:
Chris Wysocki May 11th, 2009 07:29 AM
do you know if the cineform codec work with vegas 9 64bit?
Jay Bloomfield May 11th, 2009 11:46 AM
In the last link that I posted, David Newman from Cineform says they are working on a 64-bit codec for Vegas 64 bit. In Vegas 8.1 64 bit, you can import and export Cineform, but only as MOV files (not AVI), so I would suspect that this workflow still works for Vegas 9 64 bit. I won't be able to check that (or AVI files) until later, since I haven't downloaded my Vegas 9 upgrade yet.
The problem with Vegas 8.1 64 bit is that it uses 32 bit codecs via a surrogate program, which the main executable spawns whenever importing or rendering occurs. Unfortunately, that whole process did not work correctly for AVI files, needing a 32 bit codec, like Cineform. It's possible that this issue was fixed in Vegas 9.0.
Jay Bloomfield May 11th, 2009 04:24 PM
After reading the comments on the Sony Vegas message board, I'm holding off on installing Vegas 9. Here's what I gathered from the various comments. You can still import and render CFHD MOV files with Vegas 9 64 bit, but no AVI support. One big problem that seems universal the 32 bit version is that the CFHD preview rates (only from the Vegas time line) have fallen off drastically from Vegas 8 to Vegas 9. Vegas 9 now has the preview mode defaulting to using all available CPU cores, where in Vegas 8, it only would use one core for previewing. This seems like it would make previewing faster, but apparently, it doesn't.
