-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   mocha and cfhd (https://www.dvinfo.net/forum/cineform-software-showcase/192542-mocha-cfhd.html)
Idar Lettrem April 13th, 2009 07:52 AM
mocha and cfhd
It seems to me that Mocha for ae cs4 (win) won't import cfhd files ( 1440x1080). Is it me doing something wrong here or ...?
Rob Read April 13th, 2009 09:23 AM
I too have problems with CFHD and Mocha for AE (CS4). Last time I tried, I only saw white. As such, I haven't tinkered with it much.
David Newman April 13th, 2009 11:15 AM
What importer are you using? The beta or the one in Neo Scene or neither (i.e. VfW)?
Rob Read April 13th, 2009 11:33 AM
I have Neo Scene v1.20 Build 112 installed. I have other issues with CS4, Sony DVDA and Windows Explorer too. I have opened a support ticket already about this all.
Idar Lettrem April 13th, 2009 01:34 PM
mocha
What importer do You mean ?
Mocha enables you to import a variety of files - I should anticipate same possibilities as for AE itself .... but my cineform sfw is Prospect HD if that's what you asking for ??
In mocha :
Native ex1 (1080 p) imports ok, same with cfhd 1080p BUT 1440x1080 cfhd faults with " failed to open the movie file, check that the file is readable"
(btw : still unable to run hdlink as standalone but prospect works ok inside ppro)
David Newman April 13th, 2009 01:46 PM
If 1920x1080 works and 1440x1080 doesn't, that is someone support issue (Mocha, AE or CineForm?), but it is not a forum question.
Idar Lettrem April 13th, 2009 02:57 PM
Originally Posted by David Newman (Post 1088435)
.. that is someone support issue (Mocha, AE or CineForm?), but it is not a forum question.
Sorry - didn't know restrictions applies to what relevance questions should have here ( could you please direct me to a listing of such terms) , but I will ask the folks over at the AE forum on this.
Jay Bloomfield April 13th, 2009 07:45 PM
I'm running Mocha 2.0 Soho (The AE CS4 version) and with the beta Cineform importer, it works fine with both sizes of CFHD avi files. The preview is slow, but what else is new?
That aside, I've been getting a few crashes on start up with Premiere CS4. The event type is BEX, with the faulting module being "CFHD.DLL_unloaded", which makes no sense to me, since isn't that the VFW codec? I checked the plugin logs from Premiere and the beta CF importers (both AVI and MOV) are being loaded without a problem. No big deal, but I thought that you might want to know this.
David Newman April 13th, 2009 07:56 PM
Interesting, CS4 is an odd beast as it seems to use both components. AE uses the VFW codec for thumbnails both everything else uses the new importer -- weird.
