dv in hdv project
I captured dv in hd link. Then imported into an hdv project in premier and it has a red render bar. Is there a way to capture dv in hd link and import without having to render? And is there a benifit capturing sd in hd link. Does it make it 4 2 2? Or is it better to capture sd in premier normally. Thanks TAG
HDlink doesn't support DV, only HDV and up.
Thanks David I appreciate the help.
