Playback issue
Hi Everyone:
dont know what happened, now I cant import any single Cineform file on premiere, everytime it asks me for render. I formated everything, installed everything all over again, and its not working. I installed a previous version first, one that i know worked for me in the past but now is not. Dont know what to do, I have a deadline on monday and I´ve lost three days trying to fix this. I´ve checked all the possible configurations on the playback options and none is working. A strange thing is happening though even when I load rendered CF files the playback options displays the globals. In the past this was available only in RAW files. Please help!!!!! |
First, what version of Premiere, CS3 3.2, or CS4 4.01.
Next, what version of CF do you have? Neo, Aspect, prospect? |
Sound like Premiere is confused, which can happen. Confirm if it is the project, start a new project and bring in some CineForm AVI into it to see it they are real-time (or not contact support.) If that work, import the bad project into the work project. This will typically fix Premiere wackiness.
Hi
I had also suffered from that problem premeir ask for render for fineform files.I found time remapping key makes it happend when we off the timr remapping key off. it doesn't ask for render but when we off time remapping the clip on the time line srink
Milan,
Good point, that is a long term Premiere bug, and yes disabling the key frames on time remapping can fix a lot of projects. |
| All times are GMT -6. The time now is 05:02 PM. |
