Switching to mac
I am setting up a mac pro system for editing. My question is rather simple. Using windows, I was editing on premiere pro cs3 with aspect HD. How can I still use the cineform avi files I have on the mac (still with CS3).
Thank you, Stathis |
Stathis, you can use CineForm's Neo HD or Neo 4K for Mac with all of your CineForm footage. We do not have the the RT CineForm engine ported to PPro on Mac however, so the RT editing experience isn't as high as with Aspect (retired) and Prospect on Windows. You'll use the effects, transitions, etc, provided through PPro.
Using CS3 you'll have a Red render line over your CineForm footage although it will play fine. Using CS4 on Mac will be a bit better because our CS4 importer will be available in about two weeks, plus PPro adopts an FCP-like feature of using an Orange line instead of a Red line. The Orange line doesn't force renders for some playback as the Red line does. We have a Trial of Neo HD (Mac) so you can experiment with this. ****Edit: Sorry...the Windows version of the CS4 importer will be about two weeks - it'll be a bit longer for Mac. But you can still use Neo HD Mac with CS4 - you just get the Red line for now. |
Thanks for the reply David.
If I install the NEO player, I will be able to edit in Premiere the cineform avi files I already have, right? Also, do I get any discount as I have purchased NEO HDV and Aspect in the past or it doesn't work like this when switching platforms? |
| All times are GMT -6. The time now is 02:07 PM. |
