-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Neo Scene won't capture (https://www.dvinfo.net/forum/cineform-software-showcase/141281-neo-scene-wont-capture.html)
David Morgan January 9th, 2009 11:58 PM
Installed demo version. Capturing HDV format.
Open program and transport controls work. Set preferences to capture and convert. Program stalled. Reset to capture M2t. files only, convert after. Hit capture/start and nothing happens. Get spinning windows icon. Have to close the program.
2nd question: do u have to open Scene as a separate program or can it be set up to open with the capture selections inside Vegas.
3rd question: How do u preview (look at) the capture once it's happening or as it's happening? Can you? Does the Vegas capture preview window come into play?
thx
Vegas 8
Windows vista
firewire 400 drive via express 34 card
Macbook Pro
Canon XH-A1
Neo Scene demo
Eugenia Loli-Queru January 10th, 2009 09:51 AM
1. Can Vegas capture the video? If not either, then the problem is with your PC.
2. It's separate.
3. You look at the footage after it's got captured, and you keep/delete what you want afterwards. Cineform will capture everything, until you tell it to stop.
David Morgan January 10th, 2009 10:23 AM
yes, I can use Vegas to capture video, either DV or HDV. The Cineform capture is not working.
#3-So the only way to watch what your capturing is to use the camera viewfinder?
thx
David Newman January 10th, 2009 10:46 AM
File a support ticket, cineform.com/support
David Morgan January 10th, 2009 12:11 PM
Filed...............
Robin Davies-Rollinson February 2nd, 2009 07:06 AM
David, I'm getting exactly the same problem trying to capture HDV from my FX1. Neo Scene closes every time with either option...
David Morgan February 2nd, 2009 08:19 AM
Forget it. Just use Vegas directly and edit in HDV. It can handle it.
