(Will This work?) Existing Project in CS3 HDV mode - Swich everythign to Cineform.
Have project already partially edited in CS3's native HDV mode. > I want to convert all files to Cineform codec and edit in Cineform mode. ( This is an composting heavy project )
If I convert all my files to cineform in HDLink, will i be able to go into premiere and make offline all the current HDV files and change/re-link the source file to the new cineform file (of same/similar name). This way i want to keep all my bin data ( comment/description/good/color code, ect ). I have about 300 shots and they have all been logged by descriptions. Just never tried this and asking if there is some other method or better tactic. My Plan; In premiere, I import the existing HDV project into a new Cineform HD Project. Make all HDV files offline / select original files exist on disk / and re-link to the cineform Files of the same name. Will this work? Do the files have to have exact same name? |
I've never done this exactly, but I suspect that the clips will have to have the same names to link properly, unless you want to relink each clip manually.
You might consider opening a new test HDV project, importing just a handful of HDV clips, "edit" them a bit, add some metadata, etc.,then import that project into a Cineform test project, and proceed as per your game plan. You'll quickly see what the snags are, and can gauge the feasability of trying to move a big project. Good luck |
| All times are GMT -6. The time now is 07:34 PM. |
