-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Viewing timecode (https://www.dvinfo.net/forum/cineform-software-showcase/132308-viewing-timecode.html)
Dustin Daniels September 17th, 2008 09:09 AM
Viewing timecode
Hi all,
I would like to view the timecode from the original footage (while editing). It was a multi-cam shoot that was brought in from HVX 200's, converted to AVI using HD Link. Everything converted fine and was brought into PPro and using the correct Aspect HD project settigns fine but....
The filters that I've used within PPro 2.0 (Video Timecode & Matrox Time Code) simply generate new Timecode from the timeline. I'm not seeing anyting offered in the CineForm folders. I'm used to Final Cut Pro in the way that you can simply grab the filter throw it on the footage and seeing the original TC source from the raw footage. Am I not able to do that within this workflow? I can't seem to get an answer from the Premiere forum.
-Dustin
Ian Lewis September 17th, 2008 11:26 AM
The Timecode filter in PPRo can be set to show programme timecode (default) or source timecode. Or both. But that might be new in PPro 3. I skipped PPro 2
Ian
Dustin Daniels September 20th, 2008 05:06 PM
Thanks Ian, I'll take a look.
Dustin Daniels September 27th, 2008 09:11 PM
Ian,
How did you program your timecode filter?
-Dustin
Ian Lewis September 28th, 2008 02:55 AM
In PPRO CS3, drag the timecode filter onto a clip. Select the filter in effects controls. You have a number of options, including selecting "clip" or "media" for the displayed burnt-in timecode. "Clip" is the timeline timecode. "Media" is the original camera/tape timecode - provided you have captured the video with timecode, or assigned timecode to the clip, of course.
If you have (for example) captured a tape but for some reason there is no original timecode in the file, you can tell PPro what the timecode should be, and it will use that from then on. Load the clip in the source window, move to a frame for which you know the timecode (for example the first frame of picture after bars) make sure the ckip is still seelctd in the project window and choose file/timecode form the main menu. You can then assign the timecode of your choice to the current fram or the beginning of the file. This does work. I've done it a lot (though I don't need it so much now with Cineform's online workflow...)
Ian
