NeoHDV fails to scene split HV30's 24F video stream
I used HDLink from NeoHDV to capture 24F footage from my HV30.
I have the "Split file on scene changes" and the remove pulldown checkboxes enabled. However, HDLink fails to create new file for each scene change. Is this a known limitation of Neo HDV? Thanks Yang |
There is a weird bug with some HDV camera, if you never set the clock in camera, we can't see the scene changes. Set the clock and the new tapes you capture will automatically scene break correctly.
Oh.. so my previous tapes which was shot when the camera did not have the internal clock set can not be scene-split by NeoHDV during the capture process?
That is correct.
