-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   P4K 720 issue (https://www.dvinfo.net/forum/cineform-software-showcase/123341-p4k-720-issue.html)
Rohan Dadswell June 9th, 2008 04:22 AM
P4K 720 issue
Have upgraded from P2K to P4K but have run into a problem in Windows Explorer.
Have been shooting with the SI-2K, in Explorer, whenever I open a folder that contains some 720p shots Explorer hangs. If the folder has only 2K footage, no problem. Can edit in Prem Pro with no issue, will happily import and cut, slice & dice both 2K & 720.
Makes it a bit hard to transfer shots between drives unless I take the whole folder.
David Newman June 9th, 2008 09:03 AM
Send info to support to see if they can reproduce the error.
Jason Rodriguez June 12th, 2008 09:58 AM
Hi Rohan,
Let us know if you need us to host a clip for you that CineForm can reference.
Jason
Silicon Imaging
Rohan Dadswell June 12th, 2008 03:56 PM
Thanks Jason,
Have submitted a ticket to Cineform support (haven't heard back yet).
I notice on David N's blog that there is a 'Memory leak found (and fixed) in the 3D LUT engine for CineForm RAW' and that they are making build 168. Hoping that this will address the problem.
If they do need footage it would be great you can host.
cheers
Rohan
