-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Sony Handycam AVCHD not converting (https://www.dvinfo.net/forum/cineform-software-showcase/122072-sony-handycam-avchd-not-converting.html)
Stacy Rothwell May 20th, 2008 06:36 PM
David,
Got a brand new Sony HDR-TG1 AVCHD and its files will not convert to Cineform in HDLink.
First, though, I have a question about the Cineform web site where it discusses what you need to convert from AVCHD. The first option is to have Premiere Pro CS3. I have this, but PPro will not play the file either.
They seem to be standard AVCHD files ending in a .m2ts extenstion. The Playstation 3 plays it just fine, right off the memory stick.
Now the native resolution of this camera is 1920x1080/60i AVCHD, but you can dumb it down to 1440x1080/60i. Neither of these work with Cineform or PPro CS3.
Any ideas?
Stacy
Tim Bucklin May 20th, 2008 06:53 PM
Hi Stacy,
Is there a short clip you can send us for testing? You can use YouSendIt.com to send me a 100MB or smaller clip (tbucklin@cineform.com) and I'll take a look.
Also, which version of our product are you using? If it's NEO HDV or Aspect HD, you may try setting scale to "1440x1080" in the HD Link prefs for your conversions.
Stacy Rothwell May 20th, 2008 07:08 PM
Tim,
I have sent the file to you. thanks for looking at it.
I am using AspectHD.
Stacy
Tim Bucklin May 20th, 2008 07:28 PM
Hi Stacy,
I seem to be able to convert without problems.
Can you please tell me what your HD Link log message says when you try to convert it? It will tell me if the expected AVCHD decoder(s) are not present when trying to convert.
Also, please let me know if manually scaling to 1440x1080 helps the situation.
Stacy Rothwell May 21st, 2008 02:33 PM
Tim,
After I installed (the name escapes me) the third party software that Cineform reccomends, I got it to work. However, it installed some new TS splitter program that completely screwed up the Sony software that's used to transfer and convert stuff off the camera.
Which takes me back to my other question..... In the directions on the cineform site, it says you can either have PPro CS3 installed or use the third party app.
I have CS3, but HDLink won't work.
Any ideas?
Thanks for your help
stacy
Martin Rahn June 12th, 2008 07:46 PM
Sony Cam AVCHD nor converting
I have the same problem with a Sony HDR SR11.
I tried to convert the AVCHD files using whatever codec PPro CS3 provides as per your tech notes but it doesn't work. I set HDLink to convert to 1440x1080. HDLink hangs after about a 50% conversion and starts again in an endless loop.
I did download the software recommended but the Haali splitter makes the Sony provided software to read these files useless.
Have you guys come up with a fix?
Many thanks,
Marty Rahn
Stacy Rothwell June 12th, 2008 07:59 PM
Many thanks,
Marty Rahn
Yeah, this really sucks. The best I have been able to come up with is to install the stupid Haali splitter, convert to AspectHD, then uninstall it, which makes the Sony software work again.
What a pain in the butt! I also wish someone would explain exactly what compatibility there is with just having PPro CS3 installed.....
Tim Bucklin June 13th, 2008 04:17 PM
If we look at the conversion process as a chain, it might help clarify why these other tools are needed to convert properly.
1) At the start of our chain is the AVCHD file.
2) In order to do anything with it, we need to split it into audio and video streams. This is why we need the Haali Media Splitter. There is no other splitter available (and compatible with HD Link) present.
3) Once we have our separate streams, we need to decode them. This is where PPro or CoreAVC comes in. These are the decoders we can use.
4) With the source decoded, we can now encode it into CineForm
5) Finally, we write the CineForm-encoded data and uncompressed audio into an AVI or MOV file.
Graphically, it looks a bit like this:
(1)AVC-HD File --> (2) Splitter --> (3) AVC-HD Decoder --> (4) CineForm Encoder --> (5) AVI/MOV file
So, as you can see, if the splitter or decoder part of the chain is missing or broken, the conversion can't take place.
It's interesting to know that the Haali splitter causes problems with the Sony software.
There may be another way for us to envoke the Haali splitter so that it wouldn't interfere with the other programs, but it would require that we distribute it as a stand-alone ActiveX file. We'll check into the licensing regarding that option and hopefully come up with a solution in the near future.
Martin Rahn June 13th, 2008 06:35 PM
Tim:
Thank you for the explanation of the need for a splitter.
It would be nice to have a permanent fix for the Haali splitter interfering with the Sony Media Player for playback of AVCHD clips. On the other hand, I am not converting clips every day. I can review them on the Sony software and when I am ready to edit a project, I will batch convert the clips using Haali and HDLink.
Yes, it is a pain, but not THAT big a pain. Just install Haali, use it, uninstall it and put the installer in a safe place.
Thanks again for the clarification. I was really wondering what the splitter was splitting!
Marty Rahn
Tim Bucklin June 16th, 2008 12:29 PM
There may be an easier way than installing/uninstalling. You may just need to register and unregister the splitter.
from the command line:
When you want to use it for HD Link conversions:
regsvr32 "C:\Program Files\Haali\MatroskaSplitter\splitter.ax"
When you want to use the Sony Media player:
regsvr32 -u "C:\Program Files\Haali\MatroskaSplitter\splitter.ax"
If your root drive isn't C:, your path will vary, but hopefully you get the idea.
I'll be working today in trying to use the splitter unregistered and see if that helps things. I'll post a beta build for those of you interested when I have something to test.
Stacy Rothwell June 16th, 2008 05:22 PM
Thanks, Tim! We appreciate your help with this.
Stacy
Martin Rahn June 16th, 2008 05:47 PM
Stacy
Ditto Tim.
Thank you for your help. You guys are great.
Marty Rahn
Stacy Rothwell July 3rd, 2008 10:39 PM
Hi Tim,
Any luck with this?
Stacy
Tim Bucklin July 8th, 2008 05:42 PM
Originally Posted by Stacy Rothwell (Post 902989)
Hi Tim,
Any luck with this?
Stacy
Hi Stacy,
Nothing to report yet, as I haven't been able to successfully use the splitter in the way I intended to remedy this problem, so we'll need to figure out something else.
Those "regsvr32 -xxxx" commands can be put into VB scripts to make the register/unregister quicker and easier.
David M. Wheeler July 26th, 2009 07:50 PM
Need some help. I had installed the Haali spliter to try to convert some HD movie files. But now i can play any of my movies from my SR-12 using the Sony Picture Motion Browser. So i unistalled Haali and now the movies will play again.
But the porblem is now the quility is really bad (lines thru the pictures and it skips). Any idea on how to fix what this Haali changed so i can just get it back to the way it was.
Robert Young July 27th, 2009 12:21 PM
The Sony Picture Motion Browser software does not play well with the other software we need for converting & editing in CF.
Some solutions I have used:
1) Absolutely remove the Sony software from the editing system
2) Install the Sony software on a laptop or other non editing system & use it to capture the clips + metadata to an external drive. When finished downloading plug the external drive into your editing system. HDLink will convert to CF, preserving the Sony clip names, & send the CFHD.avi to your media drive.
OR:
3) Plug the Duo cards directly into your editing system (card reader, etc.). A variety of players will play the clips directly from the cards for preview. HDLink will convert the AVCHD files to CF directly from the cards, but you will lose the Sony metadata & clip naming ( you will only get 0001.avi, 0002.avi, etc.).
Once you get this organized, it is bulletproof and fairly quick- very quick if you don't need the metadata.
