-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Cineform Premiere memory settings (https://www.dvinfo.net/forum/cineform-software-showcase/119880-cineform-premiere-memory-settings.html)
Deniz Ahmet April 21st, 2008 03:31 AM
Hi ,
With regards to the cineform control panel settings in premiere (Aspect/Prospect) there is a slider to adjust amount of memory for frame buffer (something like that). Can I ask why this defaults around 50% and what penalty I might have for using it at 100%? Running Geforce 9800GTX 512Mb FYI.
Thank you
David Newman April 21st, 2008 08:36 AM
This buffer uses system RAM not GPU memory. It sets however many frame to play head. Useful for complex sequences to have a larger buffer, but generally playing 20-30 frames ahead works well (the default.)
Deniz Ahmet April 21st, 2008 09:38 AM
Ok I understand. So if I set to 100% it would make scrubbing less responsive due to buffering, or nothing to do with HDD access....?
David Newman April 21st, 2008 11:03 AM
Only playback uses buffering, not scrubbing.
