beautiful slow-mo from Cineform files!
Okay, so I've discovered that my HV20 HDV footage provides FLAWLESS slow-motion in Avid as long as I convert those HV20 files through Cineform first. So as long as I'm editing with the ingested Cineform Neo HDV files (which has converted the HDV to progressive) the quality of my slow motion is amazing. The quality over all is amazing actually.
So I have a question. I have edited another project that was destined for broadcast. As the broadcast version would be NTSC interlaced, I didn't use Neo HDV to convert the HV20 footage. (Plus, it would have taken more time than I had to do that conversion.) But now that the broadcast version of the film is done, I'd like to go back and do an edit for festival release. This version wouldn't have to be interlaced, obviously. And I want to take advantage of that smooooth slow motion I was getting from Neo HDV files. Any ideas about what steps I'd take to re-capture the HV20 tapes through Neo HDV so that I could use an EDL list from my existing "interlaced HDV" project to reimport the Cineform files (QuickTime). Will the QuickTimes from Neo HDV have the same timecode as the tapes? I'm not even sure how Avid does a "conform" from digital based media. |
Wow. This thread has attracted a number of views. But no attempts at an answer. Maybe I posed a difficult complicated question, and I might have better luck by simplifying my question:
Do the Cineform QuickTime files retain the same timecode as the HDV tapes? Cheers! |
Confusing
The interlaced broad cast version is NOT giving me smooth slow motion. I get really smooth slow motion in OTHER PROJECTS--projects which have only used Cineform Neo HDV files (transcoded from the HDV tapes). The HV20 does insert a pulldown, but without flags, and it seems like Cineform is the only product that can really get the 24p out of it with much success. But I've only had really good results when transcoding to Neo HDV FROM THE TAPE (ie., file to file transcodes have artifacts). Thank you for your thoughts! Yes, I have a feeling that a manual workflow, as you describe, is my only option, unless there's timecode metadata inside the Neo HDV QT files that matches the tapes'. Cheers! |
| All times are GMT -6. The time now is 04:44 AM. |
