-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Approximate Disk Usage w/ HDMI Capture? (https://www.dvinfo.net/forum/cineform-software-showcase/113383-approximate-disk-usage-w-hdmi-capture.html)
Peter Moretti January 28th, 2008 05:29 AM
Approximately how much disk space per minute should I expect CineForm to use when capturing at its highest quality setting from an Intensity card?
P.S. Is a single 7200 RPM drive really fast enough?
David Taylor January 28th, 2008 09:23 AM
Peter,
Using CineForm's Filmscan 1 setting (the highest we recommend - internally we call FS2 "overkill") you can expect a compressed data rate of 15 - 20 MB/sec, or about 1GB/hour. The "High" setting will be about 15%-20% smaller.
The variable bitrate nature of our algorithm makes the variable nature of the final result because the size of compressed files is a function of the image "complexity" of the incoming source. The numbers above are for never-before-compressed sources. If you have pre-compressed source (HDV, AVCHD, even D5) your resulting files should be even smaller.
Mike McCarthy January 28th, 2008 11:53 AM
And by 1GB an hour, he means 1GB per MINUTE and therefore 60GB per hour.
Peter Moretti January 28th, 2008 05:34 PM
Mike, thanks for the correction ;).
BTW, IS a single 7,200 HD really fast enough?
David Newman January 28th, 2008 05:36 PM
Yes, a modern 7200 RPM drive sustains 35-50MBytes/s
