-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Whay are images inverted? (https://www.dvinfo.net/forum/cineform-software-showcase/112287-whay-images-inverted.html)
Andrew Dickerman January 13th, 2008 01:39 PM
Scenes captured in cineform are displayed inverted - upside down - in Vegas8. Any idea why?
(The previously captured tape shows up as normal.)
Carl Middleton January 13th, 2008 01:59 PM
Doublecheck your HDLink settings - there is one in there designed for users of 35mm adapters - it will flip the image. "M2 Lens Adapter Mode" should NOT be selected unless you want to flip the image.
Carl
Andrew Dickerman January 13th, 2008 02:11 PM
Problem solved. Thanks Carl. I should have noticed that note about 180 degree rotation.
Do you have any advice on the procedure to bring the clips from cineform into vegas8? I don't know how to keep everything properly organized so the folder and file structure is a mess.
