-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Clip Limit? (https://www.dvinfo.net/forum/cineform-software-showcase/108332-clip-limit.html)
PJ Gallagher November 19th, 2007 04:59 PM
Clip Limit?
I've just loaded up the trial version of NeoHDV and tried capturing a tape.
For some reason it cuts out after 50 clips, which is only about halfway through the tape. Just wondering if there's a limit on the number of clips the trial, or even the full, version will capture?
I'm capturing HDV 720p (25fps) from a JVC BR-HD50 deck.
Any help appreciated.
Pat
David Newman November 19th, 2007 05:26 PM
No limit in the trial or full release (they are the same.) Might be a stop on the tape that the convertor doesn't like or you ran out of disk space.
PJ Gallagher November 19th, 2007 09:51 PM
Thanks David. Plenty of disk space, so I'll try and rustle up a tape with a similar number of clips and see if a break was the problem.
Cheers
Pat
