-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Cineform and Virtualdub timeline playback problem (https://www.dvinfo.net/forum/cineform-software-showcase/106834-cineform-virtualdub-timeline-playback-problem.html)
Graham Hickling October 29th, 2007 09:50 PM
Presently with AspectHD 5.1, I can load CFHD-codec avi files happily into Virtualdub and can manually scrub the timeline no problem. I can also apply filters and render out to a new file no problem. BUT ... when I hit the realtime playback button, the image becomes monochrome and distorted (or if I enable overlay it becomes green, pink and inverted!).
I've had this problem intermittently in the past, on other machines, depending on what order I install applications. Does anyone have any potential quick fixes (i.e. quicker than a full reinstall) that they can suggest? Thanks.
David Newman October 29th, 2007 09:55 PM
VirtualDub has a bug where it asks us for RGB24 but display it as if we gave them RGB32. We support RGB32 (what Vegas uses) yet VirtualDub doesn't seem to correctly ask for it. Using play output, not play input, often gets around this issue.
Graham Hickling October 29th, 2007 10:02 PM
Originally Posted by David Newman (Post 767014)
... using play output, not play input, often gets around this issue.
Indeed it did. Simple yet brilliant! Thanks!
