Cineform Project to DVD
This is a confounding one... any thoughts would be appreciated.
I've completed a project in C2 Premiere with Aspect 4.x. I output, as usual, a finished CFHD AVI... then convert via TMPGenc to my MPEG2/AC3 files for Encore DVD. Load the files into Encore.... preview is perfect. Build the DVD, either to Image, Disc, or Folder.... and audio sync drifts (this is only a 4 minute project). Load previous TMPGenc encodes from other projects into the same Encore DVD project, and sync is good. Thinking that it is most likely an Encore issue... I try outputting a DVD Folder directly from Premiere........ Same exact trouble. A more precise breakdown of my workflow (which I use time and time again with no problem) is as follows: 1 - capture 1080i footage 2 - edit 3 - add VO 4 - output a WAV of sync sound and VO track 5 - mix sync sound/VO with music bed in Vegas 6 - drop finished/mastered audio mix back into Premiere project 7 - output CFHD AVI edited master 8 - load edited master into TMPGenc for conversion and/or de-interlacing In the past, I have run into some sync issues if the Work Area Bar has an audio gap at the beginning of the region.... but I have tried every combo of audio output on this problem to no avail. Anyone? |
