-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Hard Drive Requirements for capturing with Intensity Card (https://www.dvinfo.net/forum/cineform-software-showcase/101404-hard-drive-requirements-capturing-intensity-card.html)
James Huenergardt August 15th, 2007 11:52 AM
Hi,
One more question I couldn't find any posts on.
I'm thinking about going with the Black Magic Intensity Pro card to capture from my Z1U and my friends V1U.
I will be using either Prospect HD or Aspect HD.
I have two 500GB drives striped together in RAID 0.
Will this be enough 'bandwidth' to capture using the Cineform codecs?
What kind of bandwidth/throughput does one need to capture using the Intensity cards?
Jim
David Newman August 15th, 2007 12:08 PM
Yes that is plenty of bandwidth. The disk speed is needed for multi-layer editing, not so much for capture, which is always a single stream. As very detailed picture from HDMI, or pre-compressed component will be peak around 20MBytes/s for FilmScan 1 -- very high quality. So a single drive will do it.
David Parks August 15th, 2007 03:47 PM
So I can get this straight.
So a single 7500rpm SATA drive will capture with Cineform NEO HDV through an Intensity card? With audio and extraction?
David Newman August 15th, 2007 03:51 PM
Yes, a single average drive will be fine, even a fast notebook drive or flash device.
David Parks August 15th, 2007 04:01 PM
That is amazing. Thanks.
