Could this be a CFhd issue with PCS3?
I'm probably needing some help from somebody editing in CS3 using CFhd files.
I'm in the middle of a project and my entire sequence lost the recognition of the all the transitions and effects. Everything was running fine until the Premier Cs3 finished one rendering inside my time line and everything was gone. I'm still able to see my transition in the time line but there is no way to see the them after rendering or exporting the file with the added filters. All my project was started fresh in cs3. This is the first time that I see something like that. I lost all my added properties to scenes even that I'm still able to see them on the timeline. This including opacity, matte key, filters..... Please is anybody having any idea of what is happening here I also noticed that when I hit enter inside my time line to do rendering sometimes my program crash. Actually mostly all of the times. Is that normal for a 2 dualcore 3.0 Hpxw8400 with 4gig of memory? Is that could be related to the other issue too? |
While CineForm does have bugs occasionally, we have no controls of the database of the edits themselves, that is a Premiere only control. Did you have any previous project saves that are viable?
This my first project in the Cs3 platform so I don't have another to compare.
I'm using the most recent version of CF. I just noticed that this is a Cs3 problem cause if I reduce the length of my time line from 4 min total video with effects to 1.5 minutes is exporting everithing with no problelms.
Sometimes I wonder if Premier is really a good pro video software. Thanks David for your coperation everytime that we are in troubles. |
Cineform AHD export issue from PPro CS3
I am having a similar issue with Cineform Aspect HD and PPro CS3.
Some opacity transitions play properly in the timeline but not when exported to Cineform AVI. For example, the clip goes from 0% opacity right to 100% (does not incorporate the keyframed values). This doesn't happen on the timeline...only after export. |
Doesn't sound related, but please contact support (www.cineform.com/support.)
| All times are GMT -6. The time now is 02:24 AM. |
