Perplexing Issue With XL1 - distorted playback
Very odd issue that has me baffled.
I have a used XL1. If I record on the xl1 and play back straight from the camera image quality is fine. If I record from the xl1 and try to play the tape on any sony product that I have (a mini dv player and also a Sony 950 camera) the image is heavily distorted. I tried a tape made by canon and same thing. I should say anything I record with the 950 plays back fine on the 950 and the sony mini dv player. I have sent the XL1 to Canon and they replaced the drum but that has made no difference. Any thoughts? Thanks. |
Sounds like the XL1 is out of alignment. Several years ago I recall reading that this was a common problem with that camera. But it's odd that a trip to Canon didn't fix the problem. But I've also read that you need to be careful about fixing the alignment because tapes which were previously shot may no longer be readable.
Also, avoid LP speed it you want to reliably playback on other machines.
| All times are GMT -6. The time now is 11:39 PM. |
