Genlock a xL1s and a GL2 cameras
I do own a xL1s, a GL2 and a Videonics mixer (2 DV input and one DV output).
This is the first time that I hear about genlock and TC, and I would like to know how and if possible to genlock those two cameras. I want to cut doing offline video editing and this is the reason why I am planning to use the mixer. One camera will be connected to the mixer via a 40 meter DV (6 pin to pin) cable with a repeater in between. The other camera will be connected to the same mixer via a 20 meter DV cable. If I read other tread correctly, it is imperative that I have cable that are the same length. Am I correct ? What will I need to ensure the video signal is always synchronised when going to the mixer ? Regards ! Daniel |
It is not possible to GenLock these cameras as they have no GenLock input.
I don't think you'll run into any sync issues over FireWire cables of different lengths with that mixer. Since you already have the cameras and the mixer on hand, I suggest that you thoroughly test the set-up first. Please report what you find. |
Genlocking Canon Xl1'a
I too have a genlock question for Canon XL1 camera. I plan on doing local sports shooting and planned on using Multiple Canon XL1's. Luckily, I also read they don't come with Genlock before I brought the cameras. Is there anyway to genlock multiple Xl1'a or can you recommend cameras that do?
Considering that the XL1 and XL1s are discontinued models, sounds like you are doing this on a modest budget.
Depending on what you are doing and your editing and distribution plans (e.g., live signal, mix to tape, or tape to be edited later) it may not be necessary to have genlock. Can you give a bit more information on what you are doing, your current equipment, and maybe folks here can give some additional ideas. |
You really do not need genlock if you have a mixer such as the Videonics (even for live mixes), or if you plan to edit later using a NLE. The MX series mixers include timebase correction and a frame synchronizer to correct for any differences in sources.
Having synchronized time code on all sources can make editing easier, especially if doing linear editing (but not many folks do that these days from what I see). |
Oops, I read further it is the same company.
Yes, the Videonics line was merged into Focus several years ago, and yes should be no problem using their mixer with the XL1 series. I suspect many other mixers would work the same, but only have used the MX series. I have an MX-1 I no longer use, and an MX-Pro I use occasionally, mainly for the TBC feature at this point.
| All times are GMT -6. The time now is 01:42 AM. |
