stupid DOF question for xl1s
sorry for the stupid question, but is there a way to make your DOF more shallow with an XL1s? I don't like that my images always turn out so flat.
JT Coleman Austin, Texas |
Try opening up your iris (low f-stop) and zoom in on your subject.
If there is a lot of light you may need to increase shutter speed or add ND filters (or lower the light levels in another way). |
in addition to opening the iris, you need to put more distance between your subjects and their backgrounds. With the camera closer to your subjects, you will get a tighter DoF. DoF gets shallower the closer to the lens you get. If you can get the subject the closest to the lens you can afford to get the framing you need, you will have the most focal control. DoF on a small chip still is longer than you want, so give plenty of space behind the subjects.
I guess another way to read your suggestion is "try and place your subjects so that the background falls outside the DOF and this will also reduce the flatness of your image" ...? Btw guys, thanks again for the help !!! JT Coleman Austin, Texas |
The further you zoom in, the better DOF, so, move your camera back far away from the subject, and put the background far away, then zoom in as far as it's feasable... combine this with a large iris and you have a nice DOF
That's what makes these cameras and lenses so difficult to get good DOF because you can't always move the camera that far back and zoom in Another problem is I think the IS II auto lens that comes with the XL1s ramps up the iris as you zoom in, so you can't do 1.6 at full zoom I don't think. I'm using the 16x manual on mine, so I can't tell you for sure. |
How close were you to your subjects? I'm thinking 4 feet or less. The two options for camera placement are:
1) uncomfortably close to the subject (see the BTS in "Signs" by M. Night Shamamamamamalalalalman...look at how close the camera is to the talent at the dinner table) 2) a block away at full zoom. This brings the out of focus background close enough that you can see it's out of focus, but if you put someone in front of a tree, the leaves will be the size of their head due to the magnification caused by being zoomed in. In addition to that, the farther away the camera gets, the longer the focal range, so getting shallow DoF becomes more difficult. Which it already is when shooting on a 7mm chip (1/3 inch). The physics of lenses dictate that the in focal range in creases the further away from your lens. The best way to figure out the optimal placement is to do some tests using a tape measure from lens to subject and beyond them to the background. Start near the camera (1 foot), wide as the lens will go and write down the tape measure points where focus fades in front and behind the subject. Move the subject back a foot and repeat until you can no longer get them to go out of focus when they move backwards after you've focused on them in place. Then zoom in about half way and repeat...you'll note that the focal range is unaffected by the zoom, all it does is exxagerate the out of focus background by magnifying it...zooming also serves to flatten the 3-d quality of your scene: Cam----------Sub----------Back (wide) Cam-----Sub-----Back (2x zoom) You will not that the background is brought optically closer to the camera than is the subject...you distort space by zooming and flat is what you are trying to avoid...so have your actors get used to being able to reach out and touch the camera when they are doing their sides. I am, of course, assuming you are using this for narrative shooting where you have control over the environment and blocking and actors. |
Of course, on a thread like this, somebody has to point out mini35 adapters... skim the "Alternative Imaging Methods" board for more info.
If you have an "extra" $1000 to throw around, there are some great solutions. |
| All times are GMT -6. The time now is 08:36 PM. |
