xlr adapter explaination??
okay, well i'm alittle new to this film making and i just aquired an xl1s. i also got the ma-100 or at least i think that is the model number. it is the xlr adapter with 2 xlr inputs. anyways, i noticed it says "L" and "R" above the inputs. i know they stand for left and right and when i record audio it only records the left or right depending on what input i use. my questions are: can someone please explain how they use this xlr adapter? do you need two mics so it is not just one channel audio? is the adpater made mainly for things such as dialogue and in POST you just change the channel to center or something? please explain.
actually, if someone could be so kind to just explain the procedure of audio recording for films. this part always confused me. thanks, mike |
Hi Mike
I'm not familiar with the XL1 but the Z1 I use gives an option to either record one channel only or, in the menus to mix both channels...No dount a Canon guy will be able to tell you if this is possible on the XL also. To be honest I virtually always record one mic to one channel.... and a second to the other on the occasions when I use two mics...All my mics are mono, so there is no real advantage sound wise to having the same audio on both tracks. This gives you much better options in post for mixing your audio levels... it is a simply process to fill the empty channel, or add the audio on two tracks to mix it correctly. If I do use the audio on both tracks at once I set the volumes at different values, in case there is a really loud noise or something that can spoil the one track... hope this helps Gareth |
so basically you want two mics then? so to record the left and right seperatly?
The Canon MA-100 XLR adapter connects to the left and right channel audio input with the short cables with RCA connectors. The 2.5mm power lead conencts to the 5 vdc jack in the back of the handle. The R input connects to the right (red band plug) cable and the L jack connects to the left (white band plug) output cable only. Thus for stereo or two channels you need two mics (or use a "Y" adapter, or a stero mic).
The MA-100 uses integrated circuits (not a transformer) to do the balanced conversion, and provides about 6 dB gain. It is intended for mic-level signals and if you conencts line level signals to it it will overload and clip (distort) on peaks. It is suitable for use with all types of program material (voice, music, ambient sound) subject to keeping the peak signal input under around 0.1 volts. |
okay...then as a filmmaker you guys are, how do you set up your audio recording? or if you had the ma-100 how would you set up the audio(settings in camera, mics...etc)??
Hi Mike
For simple on camera audio work this is how I do it... 1) For scenics I'll just use a shotgun on camera... into one channel. 2) For dialogue I use either a boom into one channel and perhaps a radio lav into another. 3) Or simply use the shotgun on camera for ambient into on channel and a radio lav on the talent into the other... As I said you have more flexibility if you record things separately... For ultimate flexibility especially if you envisage using more than two mics..you'll need to look at decent field mixer like a Sound Devices 302 or 442. I use premiere pro and audition to work on the sound in post. I can duplicate the channels, adjust the audio output, mix and balance with ambient, background recordings, music etc.. Hope this helps Gareth |
just curious, i am not that fimiliar with audition, how would you duplicate the channels so it plays out of both speakers. what i really would like to accomplish is making a 5.1 surround sound dvd of a movie i film.
another thing, you talk about putting the shotgun mic on camera into one channel and the other into another channel, how do you accomplish this? i am sorry if my questions are annoying but i am trying to learn.
Hi Mike,
I've no idea about 5.1... just managing good quality mono is stretching me...I'm no expert, but my learning curve in audio has been higher than shooting as I've been a professional photographer for many year. And I now feel I'm getting there. anyway.... Quote:
In post I can mix down two separate audio tracks, one ambient and one vocal. I convert both in PPro filling either left or right channels as necessary. If the ambient is too loud I can drop the volume easily so the voice is audible.If I'd mixed channels in camera any loud ambient noise may have impaired the dialogue..keeping it separate I can remove it or turn it down.. I can then add a third audio track with music and a forth with ADR or whatever and so on... With multiple tracks I've found you've got to be really careful about clipping... I always play the sequence and always keep the Audio mixer levels from touching the red...averaging around -6db gives me the best results... Hope this helps Gareth |
You want to do 5.1 audio? And you are asking how to connect a mono mic to the camcorder. That is a large jump in the level of knowledge required, and for that matter, many modest NLEs cannot do 5.1.
Do you have the manuals for the camcorder and MA-100? If not download them from the CanonDV webs site. They provide a starting point on how to connect the camcorder. Suggest you spend some time in a library, plow thorugh back isues of magazines like Videomaker - read the stuff on audio. Then visit the web sites of the mic manufacturer like Shure, Audio Technica. Read their reference documents, white papers , etc. Same for other manufactureres of quality audio gear. Sounds like you would benefit from some over-the-shoulder help. Check if there is a Canon users group, or maybe video editing club near you, join in. The 4-channel capabiliy of the XL series does give you a basis to do some neat 5.1 stuff, at least compared to other camcordes. But I suggest that you figure out how to do plain old mono and stereo well first. Audition is Abobe's rebranding name for former "Cool Edit Pro" audio editing software. A good product with lots of capability. |
maybe I have not clarified myself...okay I am not as novice as I think I am expressing...i know my way around the camera very well and I have been using adobe premiere for several years. I just never grasped audio very well. I am very computer savvy, I should be since I'm going to school for computers. anyways...so I'm not that much of an idiot.
my main questions were how professionals do it. I know how to hook up a mic but I wanted to know how others have theirs setup to compare with mine. the 5.1 was a question because I have noticed it in premiere and never had the chance to mess around. |
Set-up is situation dependent. The sound setup depends on factors such as: what is the setting, what are the restrictions at the venue, what is the ambient sound, what audio effect do you want to achieve, will you overdub voice or mix in music in post, what is the sound source of interest, where is it relative to the camcorder/recorder, what gear do I have available (field mixer, separate audio recorder, mic assortment), is ambiend sound important or just for sync of studio sound later, crew size and skill, what can I afford to do (rent, buy, borrow) and so on.
How to meld all this together for a specific shoot is the subject of books. But in short all of the above ultimately end up in 1-to-4 audio cables that connect to the various XL series audio inputs. The camera is setup to best cope with the sound surces presented. You can do this directly to the unbalanced inputs on the XL1, being sure to select the proper input sensitivity and gain settings, or for balanced sources through an appropriate adapter. The MA-100 being and MA-200 being Canon's XLR adapters. There are a number of third party XLR adapters ofered as well - Beachtek, Studio1 and Sign Video are a few names in the moderate price range that you may encounter. I usually shoot in 2-channel mode - 16-bit/48 kHz sample rate mode, although I have used 4-channel mode for some events, such as weddings where the additional channels (for more microphone inputs) are of greater value than the slight reduction in sound quality of the 4-channel mode. But using 4-channel sound presents problems for many NLE setups because they cannot capture 4-channel sound in one pass - a work-around may be necessary depending on the specifics of your system. The suggestion that you read about audio still stands, and many of the publications do provide information on how prefesionals do sound for specific situations, often translated down to layman's terms and adapted to a modest budget. |
