-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   XL1S problem, please help (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/5939-xl1s-problem-please-help.html)
Glen Evans January 10th, 2003 07:33 AM
Hi forum,
I have just bought an xl1s "kit" with the camera and trimmings etc.
1. How do I get this thing linked to my computer?
2. What editing software should I use (on a budget)
Please please help!
Jeff Donald January 10th, 2003 07:48 AM
The camera connects to a computer through FireWire (same as IEEE1394, and Sony iLink). The FireWire connection is on the right hand side, behind the grip. Gently lift the cover between the grip and the cassette door, at the top is the connection labeled DV IN/OUT. If you editing on a Mac your in luck because FireWire ports are standard and no additional hardware is needed. If you on a PC you might have to purchase a FireWire/1394 card to fit in a PCI slot. this will require you taking the computer cover off and installing the card. If that is not your area of expertise, the store where you purchase the card will install it for you for a fee.
Many of the FireWire cards come with editing software. If not yo may need to purchase software. If you have a Mac it came with iMovie which is great for starters. You may also need to purchase a FireWire cable. The cable you need will be a 4 pin to 6 pin cable. If it's still not clear, post back with more details and I cam be more specific.
Jeff
Zac Stein January 10th, 2003 08:07 AM
Jeff,
Do macs come with a standard tv out as well to view work on a tv monitor while editing?
zac
Jeff Donald January 10th, 2003 08:18 AM
The iMacs and iBooks do not. The new G4 Towers and Power Books have an S-Video out that can be used as another monitor. There is software that will send the signal over FireWire at the same time also.
Jeff
Tim Joseph January 11th, 2003 07:26 PM
Also, once you get your firewire set up its easy from there. I have Win XP and was concerned because the camera didn't come with any software. As soon as i plugged in the the firewire and turned the camera on Windows "found new hardware: Canon XL-1s". Pretty nice! From there, any editing software should be able to import the video from the camera.
Peter Wiley January 12th, 2003 08:12 AM
iBooks and video out
The newer iBooks do indeed have video out.
There are two adapters from Apple, one is S-video out, the other is VGA. The VGA adapter comes with new iBooks.
Jeff Donald January 12th, 2003 08:20 AM
Thanks for the correction, much appreciated.
Jeff
