-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   Dual wireless mics. (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/51918-dual-wireless-mics.html)
John Dolar September 28th, 2005 07:04 PM
Dual wireless mics.
OK I have read some of the threads but still need some help.. I am trying to run 2 wireless mics into channel 2 on my XL1S via a beachtek DXA-4C add on while letting my onboard mic continue to run through channel 1. My problem is that I am only getting one of the two wireless mics showing up on tape? I have switched to 12 bit 1&2 so what am I doing wrong? I thank you for your time for this newbie. Thanks in advance guys...
John
Don Palomaki September 29th, 2005 04:33 AM
Tell us what you are doing precisely.
Whch brand/model wireless mics?
How are they configured (settings, frequencies).
How are they connected to the camcorder (precisely which jacks).
How is the Beachtek setup and connected?
What are the camcorder settings?
John Dolar September 29th, 2005 05:53 AM
info on my set up
I have the beachtek DXA-4C connected to the camera through the channel 2 jacks on the side of the camera, I am using 2 Nady Pro 351 VR wireless mics with 2 seperate frequencies, I have my onboard shotgun set on channel 1 (it is working fine) I have my menu settings set on 12 bit ST-1,2
mix select is variable, audio 1 on the menu says ---, output channel says L/R
The wireless mics are hooked to the beachtek via SLR plugs
I hope this is all the ifon you asked for.. Let me know what else I need to give you. Again thank you for helping out a novice here.. I am trying to shoot a new TV show and have already had to loose too much tape to this problem..
Don Palomaki September 29th, 2005 06:52 PM
A few thigs to check. Some may sound simple but strange things happen at times.
Is the beachtek set for the appropirate input level on both channels?
Note that the Audio 2 controls are both level, not level and balance.
Do you see any indicaton on the XL1 meters that you are gettng input from both wireless systems? Be sure the Audio Monitor setting is in ST2 or Mix setting.
Is the Audio 2 channel output missing in both analogf output and Firewire output modes?
Can you hearing the missing channel in headphones?
Have you tried the Beachtek connectd to Audio 1 inputs to test if the Beachtek and wqireless systesm is workign OK?
Have you tried swapping mics between the two channels on the Beachtek input? If that changes things you may have a bad mic or mic cable.
Have you tried swapping the Beachtek output between the two channels on the XL1 Audio 2 input? If that changes things, you may have a bad channel in the Beachtek.
Have you tried another source; e.g., wired mic, to each channel of the XL1 to verifythat it works OK?
