-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   Can't set Frame Movie Mode - Help! (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/445-cant-set-frame-movie-mode-help.html)
vuduproman December 1st, 2001 04:52 PM
Hi. I just got an XL1s (from ZGC.com) and as I am setting it up I'm encountering a problem when trying to get to Frame movie mode.
When I go to Menu, Cam. Set Up, at MOVIE MODE all I get is ..---. Am I missing something?. This happens also with 16:9, clear scan and a few others.
Any info. will be appreciated.
Paul Robinson December 1st, 2001 05:10 PM
I think it's got to do with which mode you're shooting in. A lot of functions won't work in the green square easy shoot mode, so switch it to M and try it again.....
Ed Frazier December 1st, 2001 06:45 PM
Pg 47 and 48 of the instruction manual has a good chart indicating what functions are available with each mode. CS mode must first be enabled with the Shutter buttons (only in TV and M modes) and then the scan frequency is selected through the menu option.
Ed Frazier
vuduproman December 1st, 2001 08:17 PM
Thank you
Thank you! I'll give it a try!
