-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   XL1/1s back outputs (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/38040-xl1-1s-back-outputs.html)
Shazad Rayaz January 20th, 2005 04:25 AM
XL1/1s back outputs
Hi
Has anybody got any technical details of the back phono outputs and also is that a dc output at the back?
Don Palomaki January 20th, 2005 05:05 AM
The yellow RCA jack is composite video output, nominally 75 ohms, 1 volt p-p.
The red and white RCA jacks are the Audio 1 input/output jacks., nominally 600 ohm input impedance. When in output mode, the output impedance is on the order of 3K and nominally line level.
The 4-pin DIN jack is S-VIDEO output.
The small 2.5 mm jack provides 5 vDC power for the MA-100 or MA-200 XLR adapter, and can also power (on the LX1) an RU-E3a RF unit (for Channel 3/4 output).
The green 3.5mm phone jack is for head phones
Shazad Rayaz January 20th, 2005 04:08 PM
hmmmmmmmm
only 5v
the mod im doing needs 12v dc. ohwell just have to wait till the parts arrive to see what i can do
Don Palomaki January 20th, 2005 07:12 PM
And I suspect that the 5 vDC has a rather limited power capacity in terms of milliamps. It is not designed to power significant loads.
Shazad Rayaz January 21st, 2005 04:48 AM
thanks
hmmm, the device i would of hoped to try would use upto 100mw. but it needs 12v
