-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   35mm film lenses still have to multiply for focal length? (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/3540-35mm-film-lenses-still-have-multiply-focal-length.html)
MrGranger September 4th, 2002 01:05 PM
Or do the adapters compensate? I'm wondering if it's still the 7.? multiplication to the lens?
Don Palomaki September 4th, 2002 05:22 PM
The 7.2 factor applies to the EOS adapter to give the approximate equivalent field of view relative to using the same lens on a 35 mm film camera.
Rob Lohman September 5th, 2002 01:53 AM
If you are using a true 35 mm lens with the P+S Technik
adapter for the XL1 you will not have to multiply.
MrGranger September 5th, 2002 12:37 PM
<<<-- Originally posted by Rob Lohman : If you are using a true 35 mm lens with the P+S Technik
adapter for the XL1 you will not have to multiply. -->>>
I was thinking that the 35mm motion picture lens adapters didn't do that. But someone said I was wrong...and since I might be renting on in the near future I was a bit worried. Thanks for the help.
Justin Chin September 5th, 2002 08:43 PM
MrGranger:
There is only one device that will allow you to use 35mm cine lenses and keep their field of view with an XL1. That's the mini35 by P+S Technik. With all other adapters you will need to do the 7.2 conversion.
Hope this helps.
Rob Lohman September 6th, 2002 02:22 AM
MrGranger, as Justin pointed out (and he can know because he
owns one of those amazing pieces of technology -- jaleous!)
there is only one adapter that does not have that problem. More
info on that thing can be found at:
http://www.mini35.com/
-and-
http://www.zgc.com/html/p_s_technik_mini_35_adapter.htm
Keep in mind though that this is expensive. As we like to say:
the XL1 becomes the accesory. But then again, this rig is for
rent available at some places...
