-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   Record on XL1s, playback on ? (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/31538-record-xl1s-playback.html)
Andrew Paul September 7th, 2004 02:47 PM
Just a quick question for that knowledgeable bunch out there. I have a XL1s which I have great pride in owning and would like to keep it working for me for as long as it takes for the XL2 to come down in price, (probably a couple of years). My quick question for you all is, if I was to buy a cheaper mini-dv camera just for playback purposes would this give inferior quality playback. Maybe I`m just being a bit too over cautious here, what do you guys do, do you playback on your XL1s or do use something else.
Thanks Muchly
Andy
Chris McKee September 7th, 2004 03:18 PM
You will get the exact same digital video playback from a cheap 1CCD as you xl1s.
Nathan Gifford September 8th, 2004 08:11 AM
Cheap camcorder will do fine. The only thing I am not sure will work is 4-track audio which the Canon has but other camcorders do not.
Chris McKee September 8th, 2004 09:56 AM
The 4 channel @ 32 kHz, 12 bits audio is a DV standard... as long as your NLE can capture the four channels any cheap camcorder should send them.
Few camcorders let you capture 4 channels at once, but they should all play them back.
Andrew Paul September 8th, 2004 02:09 PM
That all sounds good. So, do you all use a separate camcorder to play back on or do you just use your XL1s.
Jean-Philippe Archibald September 8th, 2004 02:14 PM
I am using a cheap ZR60 to capture. Works great, can capture the 4 channels with Scenalyzer Live, have digital to analog pass-through, and more, I was able to get it for 379$ CDN! It make a really good deck.
And as a bonus, you can record video with it! :)
Chris McKee September 8th, 2004 04:40 PM
Yes I use a cheap camcorder to capture... an older Sharp and also a ZR60 too. The tape transport also responds quicker than the XL1s I find (when pressing rewind or FF, there isn't as long a delay as when using the XL1).
Yi Fong Yu September 10th, 2004 06:53 PM
i use an optura 10 to playback footage i capture with xl1s.
