-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   XL1 / XL1S focus hunting backfocus problems (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/31-xl1-xl1s-focus-hunting-backfocus-problems.html)
Jeff Donald August 28th, 2003 01:39 PM
I don't think anyone lost interest, you said it was fixed. However, back focus usually is not an intermittent problem. Once the back focus is out of adjustment, it doesn't fix itself, so the problem should be repeatable. It would be like front end of your car going in and out of alignment. I've never heard of that happening. Try several of the tests we've suggested and see if you can get the problem to occur.
Mark A. Foley August 28th, 2003 01:40 PM
Does Canon check for any back focus problems when you send it for their recommended yearly check-up?
Jeff Donald August 28th, 2003 01:57 PM
Yes, they give the camera a thorough once over.
G. Randy Brown August 28th, 2003 04:11 PM
Thanks Jeff,
Actually, I didn't mean to imply the problem was fixed, just not noticable outside at that time when I checked it. I subsequently did the suggested test and it did indeed lose focus. It's still under warranty so I suppose I'll be sending it in.
Thanks again everyone,
Randy
David Ajax August 29th, 2003 04:09 PM
Thanks for everyone’s advice. I’ve talked to Canon again and they are going to service the camera. I will let people know how it turns out.
Bob Safay September 3rd, 2003 07:49 AM
I just sent my XL-1s in for a check up. I was experiencing the same problem. I was also told that the 3ccd chip may be a little out of alienment. I will let you all know what the results are. Bob Safay
Julian Cauceglia September 11th, 2003 07:29 AM
Focus Problem XL1S
In attempting to film a moon-set, my XL1S using standard 16X ISII lens, I find the focus moves in and out. After reading about similar problems I tried turning off the auto-stabilize and auto-focus, but it still happnes. Is it possible my lens is defective? Or is there something I missed to correct this problem.
Thank you in advance for your help.
Rob Lohman September 11th, 2003 08:51 AM
In what shooting mode were you? If you are in green box easy
shooting you can't turn of those things. Make sure you are in
full manual mode.
Ken Tanaka September 11th, 2003 10:03 PM
Also make sure that you are in Manual Focus mode.
Don Palomaki September 12th, 2003 04:31 AM
Auto focus may have difficulty finding and holding focus if the lighting level is low, below ~50 lux.
Alan Van Vliet November 21st, 2003 05:26 AM
High speed tennis with auto focus lense
I have read quite a few comments on the auto focus problems of the standard auto focus lense for the XL1S. (16x Zoom XL 5.5-88mm IS II)
Any suggestions for shooting instructional tennis videos from a varying distance of 40 - 50 feet and from 20 -50 feet.
The focus quite often begins to "hunt" right at the critical moment when the player makes his last move toward the ball just prior to contact.
Any suggestions would be greatly appreciated.
Thanks in advance.
AL
Jeff Donald November 21st, 2003 06:39 AM
Similar requests have been made in the past. Unfortunately some sports activities are not well suited to auto focus. It may take some practice, but you'll have better success in manual focus.
The AF in most, if not all, prosumer cameras is not up to the job of tracking fast motion.
Rick Bravo November 23rd, 2003 11:20 PM
Alan,
The Canon auto lenses have a hard enough time trying to hold focus on a stationary object, much less a fast moving one.
You might consider the 16X manual lens. It makes a world of difference.
RB
Mark Solleveld January 5th, 2004 02:15 PM
Focus critical but not critical
Hi all,
been reading for hours now.. but I'm afraid I couldn't find this problem:
I have a XL1, everything manual...
Zoom in on the back focus card. Get focus. Zoom out. The card is still sharp. But if I then put my hand in front of it (a feet or more away from the lens), my fingers are NOT sharp.
So you could say this is a back focus issue, but during the zooming out the chart stayed sharp. Critical focus doesn't seem to work? I used to shoot all the time all zoomed out and everywhere I went it was all sharp. But that was with another XL1..
Also, if I put a little force in my hands I can tell that the lens moves/seems a veeeeery little bit loose in the body. You can see a little bit of silver metal from the lens mount (more on 1 side then on the other side from the connection). Does everybody see a little bit of the mount or is your lens extremely tight to the body?
thanks all,
Mark
Jean-Philippe Archibald January 5th, 2004 02:26 PM
Hum... The behavior you are describing seem normal to me. You have focused on an object (in this case the card), zoomed out, and put another object (your hand) nearer your lens. The distance between the two objects explain your focus "problem". This is called the "Depth of field". There is some things you can do to increase the depth of field, like closing a bit more your iris (an higer f number).
Hope this help,
Mark Solleveld January 5th, 2004 02:54 PM
Maybe I told it the wrong way..
I zoom in.. get the focus. Then I zoom out (which on 80% or so goes out of focus and then into focus again btw) and the chart seems sharp. But then.. when I walk towards the chart, it gets out of focus again. Keeping it all zoomed out of course...
I think it's supposed to keep focus walking towards the chart zoomed out, not touching the zoom. I'll try your DOF thery tomorrow when I have a bit more light, but I'm seriously having doubts..
thanks again,
Mark
Rob Lohman January 5th, 2004 04:14 PM
Are you PHYSICALLY moving the camera after you set the focus?
If so you are also moving the focussed area and you might get
things out of focus if your lens is quite open. The more open the
lens, the less DOF.
BUT, it could be an issue with the lens itself indeed. But I'll leave
that to the lens professionals here on the forum.
Mark Solleveld January 6th, 2004 02:32 AM
Yeah.. moving it physically..
You know like when a presenter of the show you're taping suddenly approaches the camera, or wants to show his teeth or something. Shouldn't be a problem being all zoomed out normally..
Rob do you maybe know a good company in The Netherlands that can have a look at it? Or do you know the Canon repair-price (outside guarantee)..?
thx
Jean-Philippe Archibald January 6th, 2004 08:39 AM
Your camera is not broken. Whenever you change the distance between the camera and the subject, the focus will change also. Workarounds are to focus while moving, or to try to increase the depth of field enough.
Rob Lohman January 6th, 2004 08:57 AM
I'm suspecting it isn't broken either and you are probably just
"seeing" it the wrong way, or we are understanding you wrong.
With that being said, I didn't notice you were from the wetland
as well. If you want we might be able to meet up some place
and I can take a look at your camera? See if I see anything
weird?
Mark Solleveld January 6th, 2004 09:53 AM
Hi Rob,
it would definitely be nice if you could have a look at it. The thing is that in case of shooting with a tv-presenter I always used to set focus on his/her eye, then zoom out and after that everything stayed in focus, even if the presenter comes very close or even walks further away.. I really hope that the cam is ok..
If you like to please email me: marksolleveld@zonnet.nl
I live in Soest by the way..
thx all for your help
George Goltz January 23rd, 2004 12:38 PM
focus dilemma
Would appreciate some imput.
I have been doing a fashion show for a school past 3yrs, using the XL1s standard lens, and have been really dissapointed in final video as far as the focus hunting.
The models walk down on a runway approx. 50ft long they stop in the middle and at the end, camera is positioned 25ft and 90degrees from the runway at midpoint. lighting of course is not ideal and not very bright at all, need to videotape from start of walk to midpoint then to far end of runway and back to start. Camera constantly hunts, last year I tried to pan very slowly and not zoom did help a little but very frustrating at least. camera is tripod mounted, iam using an 7"external monitor , tried to use lens in manual and push focus button constantly,but how do you pan,view monitor, zoom and push focus at the same time "not doable"
any ideas?
Ken Tanaka January 23rd, 2004 03:55 PM
Hello George,
Well you've just discovered how the role of "focus-puller" came to exist in motion picture production. Focusing while keeping pace with framing and motion is a real challenge.
Use of manual focus is essential, especially in dimmer light. (All auto focus mechanisms require a moderate amount of light and contrast to operate well.) Unfortunately, using of the standard 16x lens for manual focus is a challenge because the focus ring is electronic rather than mechanical. This makes repeatable focus moves almost impossible.
I recommend rehearsing, as best as possible, with your focus before the show. You have the advantage of already knowing where the models will move. Have someone follow that same path on tthe stage/runway and rehearse the manual focus motions required to keep them sharp. (That's what's done on film productions.) If at all possible, rent/purchase one of the manual lenses available for the XL1s. These have mechanical focus rings and witness marks. You can use a white pencil to mark your range on the lens barrel.
I also recommend setting your exposure such that your iris is as closed as possible (i.e. maintain a slower shutter speed or even boost gain just a tiny bit). This will create a deeper depth of field and help to keep subjects in better apparent focus.
Good luck.
Bill Edmunds January 25th, 2004 01:58 PM
Will the standard 16x lens hold focus well?
I do not own a Xl1s (yet). I was playing around with a friends XL1s and noticed that even the slightest touch seemed to send the lens focus off a bit (in manual focus). If I remember correctly, it seemed that even changing the gain settings would change the focus (manual focus). Is this right? Shouldn't the lens hold focus better than that? Does this unit still have back focus issues?
Ken Tanaka January 25th, 2004 02:29 PM
Bill,
In my experience the 16x auto lens will hold focus when the lens is in Manual Focus mode and when the camera is in Manual exposure mode. If the camera is in a program exposure mode, such as Av or Tv the focus may drift as the camera adjusts the free parameters.
All lenses can have back-focus issues. The 16x auto lens reportedly continuously adjusts its own back focus, hence the lack of a manual adjustment such as those found on the 16x and 14x manual lenses. However, as with any other aspect of a gizmo I am sure that this facility can go haywire and require servicing.
We have had many people report focus problems with the 16x auto lens. Most were due to auto-focus matters. Some were due to operator errors. But, like UFO reports, some were inexpicable. Search around here and you'll likely find enough of each to fill your afternoon's reading.
Robert Schofield January 28th, 2004 03:59 PM
XL1 dodgy focus when zooming out
Hi
I use the XL1 in full manual mode (and I am positive it IS in full manual mode!).
If I'm focusing a frame I'll usually zoom all the way in to my subject, focus, then zoom back to ensure a sharp focus.
When I pull back the focus though the whole shot goes in and out of focus like mad.
Is this an issue with my camera (i.e. does it need servicing), or a common general issue?
Thanks in advance!
Ken Tanaka January 28th, 2004 05:38 PM
If the camera's exposure mode is in Manual mode and your manual is in Manual Focus mode, then the chances are that that the lens' back-focus is out of adjustment. If you are using a 16x manual lens (you didn't specify your lens) then follow a standard back-focus adjustment procedure. If you are using the standard 16x auto lens you will have to send the camera and lens to Canon for service. The 16x auto lens has a system that continuously adjusts back-focus but it can go awry.
One maneuver you may want to try before sending the camera for service (if you are using the 16x auto lens) is to unmount the lens, remove the main battery and back-up battery. Wait a moment and reassemble. Then see if this made any improvement. It's a long shot but worth a try.
Robert Schofield January 28th, 2004 05:53 PM
Yeah it's the standard auto 16x lens. Thanks for the info I bought the xl1 second hand and the guy said it had been serviced by canon last year, which I guess means it wouldn't harm to send it in anyway.
Thanks for the advice. If you could offer any info on the technicalities of this "back focus" it'd be appreciated too!
Cheers.
Don Palomaki January 28th, 2004 06:22 PM
You might try call canon as ask when it was last serviced. I believe that they do keep records.
Ken Tanaka January 28th, 2004 06:31 PM
Back Focus
Robert,
As you may know, camera lenses are composed of many optical elements arranged serially to perform various refractory gymnastics on light as it passes through the lens assembly. The rear-most element of a zoom lens is responsible for ensuring that the resultant image strikes the objective point (in this case, the prism or CCD block) in focus throughout the focal length range of the zoom lens.
Since this "last word" element can get out of position (millimeters count here) with use (or when the lens is mounted on different cameras) many, probably most, professional zoom lenses feature a device known as a "flange back" that enables the user to make fine ajustments to the position of this element. This adjustment, known as "back focus" adjustment, basically calls for zooming close-in on something, focusing, then pulling wide to check for consistent focus. The flange back is loosened, then rotated ever so slightly to bring the object into crisp focus, then locked. The process is repeated until crisp focus is restored throughout the zoom lens' range.
The XL1 system's 16x auto lens provides no such flange-back facility to enable user back focus adjustment. I suspect that Canon's reasoning was that, with the camera is selling into the relatively unsophisticated consumer and prosumer markets, such a facility might only lead to unnecessary service expenses as users started to tinker with this foreign gizmo.
Gee, reading this made it sound really clinical, eh? Well, I hope this is helpful.
Ken Tanaka January 28th, 2004 08:55 PM
Robert,
I just recalled that Chris Hurd wrote an article on this general subject quite some time ago. You can find it here, in the main section of DVInfo. I think you'll find it particularly interesting since it discusses your specific problem.
Robert Schofield January 29th, 2004 03:54 AM
Wonderful stuff. Thanks ever so much for all your help guys!
Edris Kamali March 15th, 2004 06:02 PM
Canon XL1s focuss problem
Hi;
I have a Canon XL1s camera and used it only once. Every time I zoom-in or zoom-out the picture became out of focuss for one second. I usually record in Auto mode. I hope someone help me with this.
thank you
Chris Staab March 15th, 2004 06:34 PM
focus problem
Focusing will be a bit of an issue until you get used to your camera. Unless you decide to.....
A) purchase the optional monochrome viewfinder
B) purchase a lens that has true focusing capabilities.
(notice the stock lens rotates through and beyond a full 360)
C) Both A and B
I know that sucks to have to do this, but I chose (C) and couldn't be happier.
Alexis Vazquez March 15th, 2004 08:21 PM
Chris, can you explain the relation between the focus problems and the monochrome viewfinder, also a little more indepth about the lens.
I'm sure new users will apreciate, me also.
AV
Jeff Donald March 15th, 2004 09:22 PM
This so called, focus issue, has been covered very heavily here in the past do a search of XL1 and focus, and you find numerous threads. This should help you get started
Dean Sensui March 16th, 2004 07:09 PM
I won't go into technical details but just relate that I had a problem with my XL1s not maintaining proper focus throughout the zoom range.
Despite keeping everything on manual, it would shift its point of focus during a slow zoom-in even though I'd zoomed earlier in to get critical focus.
I finally got the 16x manual lens and focus has stopped being an issue ever since.
And I haven't missed much of the features of the stock 16x lens except for the stock lens' ability to do a slower zoom than the manual 16x.
Dean Sensui
Base Two Productions.
Nathan Gifford March 18th, 2004 11:36 AM
Yes you will need to read some of the threads to resolve your problem. Don't forget that some of the issues may be related to changes in depth-of-field.
The high-resolution viewfinder (monochrome) does not improve focus, BUT, it does make it easier to focus the system.
Edris Kamali March 22nd, 2004 04:26 PM
Thank you all for your quick response. I am sure it will help me a lot and I will let you know of the result as soon as I try all of your suggestions. Once agian thank for your time and it is realy appreciated. I still looking forward to hear more from you.
Edris Kamali
Scott Reus April 4th, 2004 08:06 AM
NEW Focus problem w/ the XL1s
Okay, I've read every thread on focus problems w/ the camera, but I haven't seen this one. PLEASE HELP!
I'm shooting a movie and one of the shots requires my actor to lay still for about 40 minutes while the sun sets behind him (to be played much faster, of course). The camera is immobile and everything is MANUAL (triple checked). Shooting w/ the controversial 16x servo.....
With nobody touching the camera or even thinking about it, the focus COMPLETELY changes from the subject (about three feet away) to the salt on the UV filter (Grrrrr)- AND THEN CHANGES BACK about ten minutes later- AND THEN starts completely freaking out and falls in and out at incredible speeds! WHAT THE HECK IS GOING ON!! My exposure was f/10 @ 250. Camera stabilizer was on, ND filter OFF.
From what I read, this doesn't sound like a backfocus problem????
I come from a background in still photography where manual MEANS MANUAL. This shot takes forever and is hard on everybody- I CAN'T HAVE MY CAMERA FALLING OUT OF FOCUS ON ITS OWN FREE WILL!!!!!
please advise, thank you!
www.vpointfilms.com
