-   Canon XL H Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/)
-   -   Laptop HD-SDI capture (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/69872-laptop-hd-sdi-capture.html)
John Benton June 19th, 2006 09:47 PM
Any experience with this:
http://www.mobl.com/expansion/produc...ion/index.html
I am interested in their 1 Slot ExpressCard to PCI Expansion System,
to interface my Apple 133Gz G4 17" Powerbook (with a 7200RPM HD)
with a BlackMagic Decklink HD Pro Single Link - Uncompressed 12-bit HDTV SDI HD and SD Video Capture PCI-X Card with Single-Link 4:2:2 and Down Conversion and SD/HD Analog Monitoring -
It seems like it will it all "fit" together,
My question (not sure if anyone can answer this) is will it "work" - specifically for importing Uncompressed HD Video as Photojpeg/DVCPro HD/Sheer into Final Cut
Greg Boston June 19th, 2006 09:51 PM
I don't believe you'll be able to sustain the necessary data rate to capture HD with that combination. It would likely require one of the new Macbook Pro systems.
Have a look at this link to see what's coming down the pipe.
http://www.vydeo.com/products/EC34.html
-gb-
Jacques Mersereau June 20th, 2006 07:05 AM
That card looks exactly what I want to buy. Now, if Final Cut and it
work together and the cost is not too expensive I think they will have
a winning combo.
Nice work on find that one Mr. Boston.
Levan Bakhia June 20th, 2006 10:05 AM
Is it already available? if not do you know when will it be available?
John Benton June 20th, 2006 10:38 AM
It's been in development for awhile -
& the Web Page has remained the same for months
Barlow Elton June 20th, 2006 12:53 PM
I called the company and asked when the product might ship. They said they couldn't say as it is being developed for a specific OEM.
Hmmm...can you say AJA/Blackmagic! Who knows when it'll actually ship though.
Dang, I'm chompin' at the bit for a laptop SDI solution.
John Benton June 20th, 2006 01:26 PM
You & Me Both B, you and me both...
Greg Boston June 20th, 2006 02:02 PM
Actually, Barlow gets the credit for finding that. He posted it in an earlier thread and I used the link to illustrate a point.
-gb-
Luis de la Cerda June 20th, 2006 03:34 PM
Someone should just come up with an sdi expresscard and that would be the end of it. If you have a fast enough laptop to do real time cineform encoding that's about all there is to it.
Luis de la Cerda June 22nd, 2006 01:49 AM
I just found something very interesting. Aparently, the D/Dock expansion chassis for the Dell Precision M90 notebook workstation holds a pci card inside. This sounds like the perfect way to capture sdi in the field to me. The machine is a powerhouse and I bet it can do real time cineform encoding, making it an even better solution than the wafian since it does have a battery, not to mention a 1920x1200 display to monitor on. I'll have to get me one :)
John Benton June 22nd, 2006 06:58 AM
Luis -
That s a beautiful find !
But do you think that a Blackmagic card can really fit in here and do the work?
Too bad Dell doesn't have a store here where you could go in and get Tech answers
Luis de la Cerda June 22nd, 2006 04:12 PM
The best way to get tech answers would be the dell forums. Maybe if we ask around?
All I have found out so far is that it holds a half length pci card inside and it works for many notebook models out there. It's been around for quite some time now. What I haven't been able to find out is if blackmagic and aja sdi cards are half or full length. The only full length pci card I've ever owned was a DPS Velocity that bit the dust a few years back.
Tony Relph November 10th, 2006 10:49 PM
Hi,
Has anyone found out if the Dell Precision M90 notebook workstation holds an SDI pci card inside or if an ExpressCard to PCI Expansion card will work on a MacBook Pro with an SDI card?
John Richard November 11th, 2006 10:42 AM
I still think it is the capture/storage drive array that is going to give the portability problems.
To get portability (such as a Firestore device) you currently have to accept degrading compression like Cineform/Wafian or Sheer or accept more bulk in the drive array.
Jay Stebbins November 11th, 2006 01:00 PM
I just stumbled across this wonderful news....
http://www.barefeats.com/hard71.html
as well as, I was unaware of the recent 15" MacBook Pro changes... An even faster processor and a firewire 800 ports was added to the mix.
The pieces are coming or even here... But will they work together?
