Can it use existing XL-1/2 Lenses?
Sorry if this question has been asked before, but will the XL-H1 be able to use the existing 3x Wide Angle Zoom Lens (for the XL1/2) and others accesories like the EF adapter and 1.6x extender?
Thanks. |
Hola
Do you think the HD lens will call for updating one's arsenal of 72mm Century Optics adapters and the like? Not that I will ever be able to buy this new camera, but right now I'm trying to decide whether to buy the (current) 3x wide or a CO 0.6x.
I have one of the Century 0.6x adapters that I am going to be selling. If you are interested, e-mail me at timjbd@yahoo.com Thanks. Sorry for the interruption. |
Question for Chris
"Although the standard definition 20x L IS lens and other Canon XL video lenses can be mounted on the XL H1, Canon recommends against this practice as those lenses will not properly resolve for HD."
Chris, can you elaborate on this statement at all? I've read this a coupla times now, trying to figure out the lens issue, and I'm not at all clear on what it means...does it mean, yes, you can mount them but they'll look like crap, or yes, you can mount them with a loss of resolution? Or what? Do I understand correctly that 35mm Canon lenses will do well with this camera? I've read everything I can about lens compatibility and still don't get it...maybe this is a case of having to wait until the camera is released and see what actual users discover? |
The short answer Meryem is that SD lenses do not resolve sufficiently for HD... you can use them on the H1 but you'll suffer from a softer image that won't improve no matter how much sharpness is applied... just what degree of softness won't be known until the H1 camera ships to customers who already own standard def XL lenses. Then we'll all find out from user reports.
What will be interesting is if you can use an existing wide angle adapter to the H1 if IN DV mode and it works. Softening HD makes sense, but I wonder if using it in DV mode will be fine.
Just curious. KW |
I'll try my best to answer this one for you. I estimate that on average the minimum resolution these HD prosumer camcorders will resolve and capture is 700 Horizontal TV lines of resolution. Usually SD DV cams will typically resolve 400 lines of resolution (I believe the XL2 can do 600). So unless the wide angle adapter (or any adapter in fact) horrendously cuts down the resolution in half (which I doubt), there won't be a problem using it in DV mode. |
Something tells me this is just marketing hype to get everyone to buy the new lens. I can't understand how for years Canon can build film quality optics, which are being used nowadays on 12+megapixel DSLRs and suddenly when it comes to the XL series lenses they can't resolve a 2 megapixel resolution.
Maybe I'm wrong but it just sounds fishy to me. |
What is interesting about all of this is that on the DVX100 and the reel stream adapter they can get HD by using the pixel shift. While this is a pixel shifted format of HD the lens on the DVX100 is still an SD lens but samples from the reel stream product are producing some very amazing HD images. While the came is still sampling SD when you have a set of chips that have pixel shift the chips are configured 1/2 a pixel from each other so in fact the light does have to hit 1440x960 detailed points of light.
1/3" HD chips should use pixels that are about as big (for the light to hit) as a SD pixel shifted half way. The image may be slightly softer but may still look just as good as images from the reel stream product. I will be very interested to see how well the current XL manual lens works with the XLH1 when the camera finally comes out. I'm sure there is somebody out there who already has this lens that will be trying it out. |
In case this wasn't mentioned, don't use an XL-1/2 lens when in HD mode. SD, no problem.
heath |
Perhaps the question should not be why lenses for HD cameras have to be so much better than what's on the market for SD now but rather how they've been able to get away with apparently such poor quality SD lenses compared to what has been offered for 35mm still photography for years at a fraction of the price. At 2 kilobucks or more for the lens, I would have thought that a run of the mill XL2 lens would be capable of resolving far more detail and sharpness than any video camera imager on the market, especially what what seems like an optically superior still camera lens can be had for less than an eighth of the price.. |
I can understand that my Canon 16X black manual lens may not work well on the new H1, but I would think that my range of extremely sharp Pro Nikon Nikkor ED lenses that I use (via an adapter) on the older XL body should also work well with the H1.
Most all 35mm still photo lenses are "HD ready," because 35mm still photography already involves resolution requirements far beyond that of HD video. Standard definition video lenses, especially the Canon XL series, resolve only to SD requirements primarily to keep the cost low. All those older Canon XL lenses cost much less than $2000, which is considered dirt-cheap in the broadcast video lens world. Plus they're made for SD, during the watershed days of SD, therefore they didn't need to be any better than SD, because why pay for what you can't use. It's just like the old Hi-8 days and the Canon L1 and L2. You couldn't use those lenses with the XL1 nor would you want to; those Hi-8 lenses couldn't resolve for the 720x480 of SD digital video. Neither can SD DV lenses properly resolve for High Definition. |
Canon certainly can build high-res video lenses... they've been in the HD video lens business for years now. You could buy five XL2 camera kits for the price of one of those HD lenses. XL series lenses were dirt cheap, the most expensive one was never more than $1800 (the 20x IS II), and they needed to resolve only 720x480, which they did quite well. Also, for the record, at the PhotoPlus Expo in NYC last month, I had an opportunity to put an XL 3x on the XL H1 and the results were just as I expected... too soft to be of any use at all. As the H1 starts to ship to owners who have other XL lenses, they'll confirm what I'm reporting here as they're able. Hope this helps, |
I recall reading somewhere that a 35mm still frame has the resolution equivalent to a digital image sensor with something like 35000x50000 pixels. Plus larger image circles are harder to get uniformly sharp and aberration free than are smaller ones. So why does a zoom that needs to be sharp over an area about 1/3 the size and resolving a mere 720x480 start at more than 4 times as expensive at the entry level and go up exponentially from there? If we even things out image size-wise so we're looking at lines per inch resolution instead of raw pixel count, the lens shooting on a 35mm still frame is required to have more than 10 times better resolution than a lens for a 1/3" native HD 1920x1080 sensor would. Yet they're doing that at small a fraction of the video lens cost. Think it has more to do with a perceived "deep pockets" in the entertainment industry than actual manufacturing and R&D costs, sort of like the Pentagon's $500 hammers?
While $1800 is "dirt cheap" compared to other professional video lenses, a lens with a similar zoom range, better low-light abilities, and 10 times the native resolution can be had for 35mm still cameras for $100-$500. |
Certainly one significant part of the answer is the zoom motor... there's no motorized zoom on any removeable 35mm still photo lens, but of course there's a lot more to it than just this. See also this thread, the input from Chas Papert and Graeme: http://www.dvinfo.net/conf/showthread.php?t=50525 By the way I always defer to these guys, if it looks like something I'm saying conflicts with them, you should take their word over mine every time. |
Interesting discussion. Part of the explanation will be that while SD requires only 720x480 resolution, that resolution is required within a MUCH smaller area that the 24mm by 36mm area that a standard 35mm still camera lens has to work with.
So in that sense, the video lens still has to provide a high resolution, just over a rather narrow angle angle. If I had a bit more time I'd do the math, but hopefully you'll understand what I'm on about. |
A 35mm movie film frame is about 22mm wide; a 16:9 1/3" CCD is about 5.24mm wide.
Assuming a movie frame is scanned at 4k resolution, that puts 4,000 pixels (or thereabouts) in 22mm, or about 182 pixels per mm. On a standard-def 1/3" CCD you're talking about 720 pixels in 5.24 mm, or about 137 pixels per mm. But in high def, you're potentially fitting 1440 pixels across, or nearly 275 pixels per millimeter! On the vertical, it's even worse -- 1080 lines in 2.95mm, or 366 pixels per millimeter. TWICE as dense as 35mm cine film! A high-def 1/3" chip then needs lenses that are substantially sharper than even cine lenses need to be. Using a standard-def lens runs the risk of not resolving nearly enough for the incredibly tight demands of 1/3" high-def. And, totally off-topic but tangentially related, it also makes me wonder if we'll ever see that rumored high-def GL3. The GL1 and GL2 were 1/4" CCDs. Would it even be possible to make a 1/4" high-def CCD? Maybe 1/3" is as small as high-def can go; at 366 pixels per millimeter, we're already being limited by optics as to the ability to resolve the image. Making the chip smaller and still able to resolve the full resolution may actually be impossible. |
Interesting... So, since the lenses seems to be the most expensive part of HD cameras, in order to cut the price to enable everyone to buy an HD cam, manufacturers will have to put "bigger" CCDs? It could be a really interseting side effect of the HD revolution.
Larger CCD’s and faster data transport systems could really change the way we shoot video soon!?!? It does seem that making larger CCD’s will be preferable to much more expensive lenses. And, lens making is what you might call a “hard industry,” and is not going to undergo rapid updating of procedures and methods. Dang things will still have to be ground and polished out of the finest materials. The future looks interesting indeed! Mike |
Barry,
With pixel shift on SD cameras isn't there extra small points 1/2 the size on the CCD's that end up giving much higher detail than 720x480? If a SD lens cannot handle more detail than 720x480 then wouldn't pixel shift be kind of useless since shifting the CCD's wouldn't gain any extra detail anyways because the lens would be limited to 720x480? I do think certain SD lenses can resolve more than SD resolution. It may not be as much as a HD lens but it might still look good. Even current 1/3" HD lenses don't seem to resolve the full 1440x1080 anyways. I will be very interested to see resolution tests of a SD lens on a HD camera to see how bad it actually is. Maybe it would only be a little bit softer kind of like a diffusion filter. What I do know is that the lens on the DVX100 is a SD camera with a SD lens but by using the pixel shift the reel stream product does gain a lot more detail to create a HD image. Here the SD lens does seem to resolve a lot more detail than just SD. |
I think ARRI and another company (Sony? Panasonic? Neither? don't know for sure) already has a camera with a 35mm sensor. I believe I read it once, not sure. Still, I don't want to know the price of the thing at this moment ;-) |
The Panavision Genesis has a 35mm size sensor.
See:- http://www.hollywoodreporter.com/thr..._id=1000527854 |
I gather the obstacle to putting a large chip into a video camera on the cheap is that you can't achieve an adequate frame rate. Large-sensor 50fps requires a MUCH more expensive chip than the typical digital still camera uses.
But meanwhile, people that dont require real-time framerates (e.g. stop-motion animators) do indeed use digital still cameras to generate super-high resolution footage. |
A large sensor could use large pixels
"I gather the obstacle to putting a large chip into a video camera on the cheap is that you can't achieve an adequate frame rate. Large-sensor 50fps requires a MUCH more expensive chip than the typical digital still camera uses."
It is possible to keep the data rate the same by building large sensors with large pixels and same pixel count (versus leaving the pixels the same size and increasing the pixel count). Benefits of such an approach would include improved noise characteristics and allow narrow DOF. |
Basically, as Barry puts it, it comes down to pixel size on the sensor. As you try to fit more pixels (ie HD) into a smaller chip, ie 1.3", the resolution, in line pairs per mm, that the lens has to be able to pass, is necessarily greater and greater.
Although lens cost is usually proportional to the square of the radius, hence bigger lenses for bigger chips being exponentially more expensive (and lenses for smaller chips very much cheaper), this is not really mitagated by the extreme sharpness demands of HD video on 1/3" sensors. That's why you get affordable "HD" lenses that are only sharp in the middle, not at the edges, have severe chromatic aberations, and breathe heavily on pulling focus. Canon make great lenses for 35mm stills cameras, but even so, you need to get the expensive L series lenses to fully do justice to the smaller pixels on the 20D compared to, say the 5D or 1dsMK2. Although the sensor is smaller on the 20D, so if the lens is a bit soft at the edge, you don't see it anywhere near as much. Hope that helps, Graeme |
| All times are GMT -6. The time now is 11:22 PM. |
