-   Canon XL H Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/)
-   -   London Preview of Camera (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/51305-london-preview-camera.html)
Bob Thompson September 18th, 2005 11:50 AM
Unfortunately the following link is in German
http://www.slashcam.de/artikel/Beric...anon-XLH1.html
Eric Brown September 18th, 2005 03:09 PM
Just a quickie thought.
If anyone has a link in a foreign langauge the best thing to do is locate that particular webpage through Google and click on the "translate" option.
Here is the English version
http://translate.google.com/translat...lr%3D%26sa%3DG
Dylan Pank September 19th, 2005 04:54 AM
Hmmm..
"A natively progressive recording does not give it"
Seems to answer that question.
Thomas Smet September 19th, 2005 07:38 AM
hey thats some great Yoda talk.
Chris Hurd September 19th, 2005 08:26 AM
Interesting this page is. Learn from it you will. But its accuracy, question you must. Curious this statement is:
"Signal processing 8 bits or 10 bits? All signals of the Canon are placed 8-bitig to the order and correspond thereby to the standard."
Strange that would seem... from Canon confirmation do I seek.
David Newman September 19th, 2005 10:02 AM
Chris,
Placing 8-bits on a 10-bit protocol is just odd -- so I won't believe it (testing will be easy.) 8-bit data over HD-SDI is just 10-bit data with the bottom to bits set to zero. Canon will have enough sensor precision to deliver 10-bit data over HD-SDI, not doing so doesn't make any sense. When you use the HDSDI feed the camera is just a head, and no longer needs to "correspond thereby to the standard." The standard is then HDSDI, which is 10-bit.
Chris Hurd September 19th, 2005 11:06 AM
Thanks, David, that's what I'm expecting as well.
The reluctance at this point in time to officially disclose the bit depth of the DSP or the SDI output is a conservative move typical of Canon Inc. (Japan), and in my opinion that policy is more of a back-firing liability to them than anything else. There's nothing like an unconfirmed technical factor to spur controversy.
