-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   Replacing the Flourite coating (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/76431-replacing-flourite-coating.html)
Allen McLaughlin September 29th, 2006 03:21 AM
Whilst out shooting with a friend and our XL-2's, we noticed what looked like a smudge on her lens whilst checking playback.
On closer inspection it would appear not be something on the glass but something missing from the glass, i.e the flourite coating ? It looks like a tiny chunk the size of a pea has come off.
Is this possible, has anyone else experienced it and what would be the likely repair bill to have the optic recoated ?
Michael Salzlechner September 29th, 2006 06:16 AM
Generally only if either the coating is defective or certain liquids can destroy the coating
AFAIK the coating can not be replaced. The front element can. Generally front elements cost a few hundred plus labor. But i would check with canon
if it is still under warranty they may replace it under warranty if the coating was defective
Andrew Khalil September 29th, 2006 10:48 AM
if I'm correct, the coating isn't fluorite, but the actual element is. I don't think you can repair it - you'll need to do as Michael said and get them to change the actual element.
