Practicality of S-Video out
Hey. I read recently that the analogue image that comes out of the XL2's S-video port looks quite abit better than the image recorded to either tape, or via fire-wire. Now, how feasible is it to record onto a laptop live, through an S video port. What type of external graphics cards can be hooked up to do this, and wouldnt then running the signal through the 1394 port look the same as doing it through the firewire in the first place?
am I making sense? Harder to type more detail, but hand is still broken. Matt |
From experience the difference between the S-video and DV signals on consumer cameras is negligible. Especially when viewed on a consumer monitor (tv set).
I'm not sure why you want to record via S to a laptop when firewire is the best and most readily available option ? You'll need to install an analogue capture card with an S-video (Y/C) port, as well as having the necessary analogue audio capture card with phono/RCA throughputs. |
-gb- |
I've read a few posts around here that would suggest that even if the video has been recorded to tape, analog captures via S-video still contain more chroma information than digital captures. Why would this be? I haven't been able to figure out how that could be possible. I'm sure it's as much of a mystery to anyone else as it is to me, but any theories? Seems kinda strange. |
-gb- |
So Greg, when you say "analog capture," you're only talking about direct-to-disk with no tape involved, right? That I could understand as a possibility. But I could swear I've heard people say that analog capture from tape still looks better than digital capture, even if direct-to-disk is even better. Maybe I've misinterpreted what these people were saying.
At any rate, I believe you when you say that direct-to-disk via s-video provides more chroma information. You strike me as a guy who knows what he's talking about. :) I'll definitely have to consider picking up an analog capture card before I shoot another project involving chroma key. |
That is what I was talking about :)
So, I would need a comp with an analogue capture card in it... what about going from an external capture card to a laptop via 1394? Would compression still take place? Or has the S video bypassed some of the compression and the 1394 is just transmitting the signal? |
OK, I tried it, and here's a couple of screen grabs for comparison. The YC grab was captured uncompressed (hence the UC in the filename) via my DV Storm card and the DV grab (DV in the filename) was captured from tape via firewire. I exported the images from Vegas 6 with all attributes set to square pixels to avoid resampling artifacts. Let me know if you have any problem downloading the files.
It's worth opening the images up in Photoshop so that you can zoom in to see the details. 300% or 400% shows up SD resolution in all its glory. To my eyes, and on my LCD monitor, the 2 images are not that much different. The YC grab's a bit less saturated, but I didn't adjust the proc amps before capturing so that's probably not too significant. It's possible that better capture hardware would yield better results from the YC input but I'm not sure how much difference it would make in practice. What I found interesting is that the vertical ghost lines next to the mic stands are more prominent on the YC grab. If anything, I thought the DV compression would have made that worse but obviously not. Anyway, I'd like to hear your comments if you have any. Richard http://www.jaegercat.com/~richard/XL2UCSquarePixels.png http://www.jaegercat.com/~richard/XL2DVSquarePixels.png |
Thanks for that Richard.
Although I am dying to see some difference, i really cant detect any! Anyone else got a conflicting result? Maybe we can see some video to compare them. |
Richard,
I notice some difference in the gray area on the sides of the speakers. Which one most closely represents the actual coloration? Thanks, |
I think the yellow thing on the wall looks richer in the svideo shot. the dv one looks a little washed out. There also seems to be slightly more noise in the dv pic on the speakers.
Richard |
Richard |
Here's another couple of grabs with brighter lighting, so I was able to set the gain to 0dB and the lens to F2.8. I changed to 4:3 mode for this to avoid the camera resampling the 960 pixels per line down to 720 that occurs in 16:9 mode. I also switched off the custom presets so that there is no (or minimised) in-camera processing. Sorry about the shadows - my camera position was constrained due to the length of the YC cable attached to my PC, and also the black cat around the legs of the tripod.
From what I can see, I have doubts whether the YC output is uncompressed after all. In any case, based on the small differences I can detect, I think I actually prefer the DV image. Richard http://www.jaegercat.com/~richard/XL2YUYV4_3.png http://www.jaegercat.com/~richard/XL2DV4_3.png |
