Image stabilization and Tripods
I'm confused about when to use the Image stabilization when on a tripod. I've seen advice for both turning it off AND for leaving it on? My still camera lenses have different modes of IS for hand held and tripod mounted, but the XL2 does not. I'll be going out to tape my daughter plating soccer and will try it both ways, but is there a relatively simple rule of thumb that I can use?
At the moment I'm bewildered/stunned/lost in all the other things the XL2 lets me adjust... |
General rule, turn it off... the only exception may be if your tripod is not very good.
ash =o) |
If you watch the XL2 Tour video at http://www.dvcreators.net/canon-xl2/ it states that the IS helps provide more stabil footage if it is turned on when the camera is on a tripod. In certain circumstances it may help, but in most it will cause problems - especially during slow pans - so I agree with Ash in that it is best to turn off the IS for the majority of shoots when the camera is on a sturdy tripod.
I'd also say depends on the tripod but also focal length, because the stock 20X lens is a very long tele lens and having shot lots of concerts and events of various types, often from far away because of camera placement limitations, I can say that when you're at full tele or close to it, the slightest bump (and I really mean slightest) will cause the footage to look like it was shot during a earthquake. People clapping or moving their feet (if you're in wooden stands for example or any similar unstable ground) might also cause this. Even strong wind can produce vibration to some extent.
In those circumstances, maybe it is best to turn it on. But you'll have to test this once you're there. Ideally you don't want to have it on because even if the OIS on the XL2 is very good, it will occasionally noticeably try to fight or compensate if you will for the movement so panning starts and ends may not ba as smooth as wanted. I actually learned to ride the IS on and off while I'm shooting. Whenever I'm passed 3/4 of the zooming range, I usually toggle it on if the vibrations are too strong for whatever reason, but I usually don't have long pans to make though, I only need to follow the talent on stage. Again, you'll want to experiment a little with this once you're there. |
I was recently testing out a new tripod. I forgot to turn off the image stabilzation function. Later, when I viewed my footage, I discovered that the entire picture was jumpy. Very distracting too. I wont make that mistake again. I hope.
Tim |
Well my experience is with Sony and not Canon cameras, but I agree with David. When you're zoomed way in then you *probably* do want to turn on image stabilization, especially if you have locked down shots. I've found this out the hard way by ruining live performance footage.
But every application has its own set of variables, so you should try some tests and draw your own conclusions. |
Seems everyone runs into this issue when the first start shooting with their xl2.
for close up work and a solid tripod the is should be off, you definitely get shimmer in your footage. with the telephoto half way out, out doors with any wind movement and the is should be on. test it out for yourself!! |
I reviewed the test footage from the soccer class, and the answer remains murky! As pointed out, at long zoom, it helps with shake from bumping the tripod and seems to dampen my poor pan technique. But at the same time, it also seems to mess with the start/end of a smooth pan. Too bad I can't get the camera settings from the footage, like I can with my digital camera.
I'll be doing some more shooting tomorrow and will try to keep better notes. I should also probably try to play with the fluid head drag settings? Thanks for the advice, as usual you guys are really helpful. |
The purpose of putting the camera on a tripod is to lock the image in place...the purpose of IS is to repsoition the frame to try to counteract movement within the frame. These two tasks don't framass well. Keep the IS off or the frame will shift around as the subjects of the shot move within the frame.
I think you're right David. I've read that Sony actually licenses their image stabilization system (Optical Super SteadyShot) from Canon. I know that the Sony system uses a gyroscope to measure camera movement, so locking it down on a tripod shouldn't cause the problem Cole describes. In fact, I think it will help on a locked down tripod shot, since any time the camera moves it's from a bump or vibration, and that is exactly what you need to correct for in a telephoto shot.
Yes David and Boyd's comments seem to match my observation. At high zoom, the IS helps stop small bumps and movement resulting from operating the camera. The only problem seems to be a slight "jiggle" at the start of a camera movement. It seems you can't have it both ways.
Depending on skill level, there seems to be a zoom level at which it becomes beneficial to switch the IS on. |
I ALWAYS have OIS on, even while on a tripod. I personally don't experience/notice any kind of pan compensation, so it's all fine and dandy for me.
The OIS on the XL's can be left on while on the tripod without a problem. It is not the same system EIS that JVC and others use, that wants to "hunt" for movement when the camera is still, thus moves around.
The only problem is in pans where you need every frame, begining and end of the shot, and that is because the camera wants to use the laws of motion. That is that it will resist the start of the movement (a body at rest tends to stay at rest--so it tries to compensate), and when you stop it tries to keep moving (a body in motion tends to stay in motion--so it tries to compensate)! So there is a little settling in at the start and the stop. If you don't need the start and end frames, or you over pan (as in a landscape, you might want to leave it on to make the pan smoother. But if you are going to record then pan, or pan to a point and keep recording then you want to turn it off. It is probably the best system out there, but they all have their limitations. They all must decide what you the operator are trying to do, and that is just not possible. Mike |
I shoot with an XL1s and I used to run with it on...on a tripod...until I noticed that I was having to reshoot all of my footage or fix frame movement in post. From what I understand (I'm sure this will be corrected), the Canon has a combination of physical correction and digital...it accounts for both. I've turned it off ever since. If it becomes a big problem, you can get relatively inexpensive LANC controllers for the camera to drive it without touching the camera.
If you have to pan at all, it's completely worthless, the pan becomes gummy at the beginnig, and then twitches back to frame, then gummy again as it tries to continue to correct the image then hits the edge of what it can correct. I simply don't trust a machine to guess what I intend for it to do. |
Well I don't know anything about the XL series, but the image stabilization definitely helps on my Sony's when shooting performances at full zoom from about 100' away. On my little PDX-10 I use a 2x teleconverter giving me the equivalent of a 1000mm lens on a 35mm still camera. Without Steadyshot turned on, tripod mounted shots (on a Miller DS-5, more than adequate for that little camera) are very shaky in our 150 year old wooden theatre.
I use a 1.6x teleconverter on my Z1 which gives me the equivalent of a 500mm lens and I have the same issues unless I use steadyshot. It really helps a LOT in fact. There is sometimes the little stutter you mention during a pan, but it's pretty rare. But the range of movement is pretty limited when shooting a performance, so maybe there are more issues if you're filming wildlife outdoors? But Brendon is specifically asking about the XL2, so I think he's taking the right approach by experimenting to draw his own conclusions. |
Boyd, are you able to do any kind of CUs on moving performers at 100' distance and keep the motion smooth and steady? That must be quite the challenge I assume.
Back on topic, I find it is possible with a bit of practice to compensate for the jumpy pan starts and ends with the IS turned on. You have to start and end your pans extremely slowly, that way the OIS will start slowly moving in the opposite direction of where the camera is actually moving until it reaches the limit of its movement range, then start moving along in the proper direction along with the camera. That will only work if you're not in a "hurry" to pan accross, so it wouldn't work if for example you were following somebody. I use a silky smooth Vinten Vision 3 head and I've been able to start and end pans with the IS on in a relatively smooth manner this way. The end of your pan is rarely a problem. All it will do is continue slowly moving a bit once you come to a halt (OIS re-centering). That's rarely too distracting. This is not a one size fits all solution however because depending on the speed of your pan, it might give you a "jumpy" effect (IS always trying to re-center while you're trying to move the camera at a constant speed). |
David is right about the speed of the pans affecting performance. I've been so used to using the 16X Manual Servo lens that I sometimes forget to switch off the IS on the 20X lens, and there is no doubt that extreme slow pans are generally OK with IS switched on, but anything between medium slow to fast pans tends induce a kind of 'dragging' affect as the IS combats to adjust for the movement.
I'm going to run some tests later today. Would anybody like me to post some "Pan Test" footage?
yes please. along with approximate # of degress panned and times so we can get a sense of how fast if possible.
