-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   XL2 mic holder (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/63122-xl2-mic-holder.html)
Luke Springer March 17th, 2006 10:47 PM
XL2 mic holder
Hello,
This may be a dumb question, but is there a way to remove the microphone holder on the XL2? I would like to attach a shotgun mic via the shoe mount, and I don't like the look of the empty mic holder attached to the viewfinder assembly.
Luke
Andrew Khalil March 18th, 2006 12:25 AM
I don't think you're supposed to be able to remove it - you could leave the mic there just in case you need it for an emergency or something if you don't like it empty.
I guess you could saw it off if it really bothers you, it's just soft rubber/plastic, but I'd hesitate knowing I'll need it one day.
Matthew Nayman March 18th, 2006 08:03 AM
I think, don't take my wor for it, you can open up the EVF and unscrew it from the inside. I would grab some hex wrenches, some screw drivers, and a digital cam to document your experiment. Take some photos for us all!
Michael Salzlechner March 18th, 2006 09:30 AM
on the mic holder where it attaches to the viewfinder on the bottom there is a single screw. Open that and remove the little plate and you can slide off the mic holder
Bruce S. Yarock March 18th, 2006 10:33 AM
I took off the canon stereo mic, and hooked up an AT897, using the same mic mount.The only difference is that I had to wrap the AT with some hard foam so it would fit snugly and wouldn't jiggle around in the holder. (The AT is thinner than the stock Canon mic).
Bruce yarock
Miguel Lombana March 18th, 2006 10:54 AM
Originally Posted by Luke Springer
Hello,
Luke
http://dvinfo.net/conf/showthread.ph...highlight=dual is a post that I had a while back, I use a dual shoe from Mamaya on my cam at times when I want to have the option of switching from the on-board mic to a shotgun. I posted about 8 pics of the setup and a possible configuration of this is something that you might want to consider.
I took a few inches of refrigerator water line tubing and wrapped it around my shotgun to give it the right size to fit in the onboard holder.
Something you might consider.
Miguel
Luke Springer March 18th, 2006 06:44 PM
I still don't know if I want remove the mic holder, I will look at my other options first. But thanks for the great feedback,
Luke
