-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   Line level RCA or Mic level XLR? (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/58308-line-level-rca-mic-level-xlr.html)
Tim Commeijne January 14th, 2006 06:52 PM
So we all know that the XL2 XLR connectors accept mic-level only, and the RCA connectors accept line level.
XLR is better than RCA and
Sending out line level is better than mic level.
So what is the best I can do? Set my mixer outputs to line and go to the RCA's or set my mixer outputs to mic-level and go to the XLR's?
Tim
Bill Hamell January 15th, 2006 09:35 AM
Tim,
Your options are…
1.) Set the mixers output to Line Level and go to the RCA connector
2.) Set the mixers output to Mic Level and go to the XLR connector
3.) Set the mixers output to Line Level and use a Attenuator between the cameras XLR and the cable from the mixer
I use a 30db attenuator when I have a line leval signal if I need more attenuation then I turn on the cameras attenuator. YMMV
Bill
Jason Varner January 15th, 2006 04:50 PM
More than meets the ear.
If you want to run balanced line out into the XL2 you need a transformer. Some mixers have a Mic/Line output but it often just an attenuator and not a transformer. It is important to note that mic and line level are two different types of signal. It would be like trying to run speaker cable into a line input. Also keep in mind the more you process the audio the more the quality will suffer. If you're not having problems with noise just use xlr-rca adapters. The fewer mic-pre's, transformers, and gain stages inline the better. Good Luck, Jason.
