AMAZING Camera... Screen grab inside
Just recieved my camera last night and all i can say is it is amazing. Thanks to b&h for the prompt delivery and canon for the amazing product. As promised i give you guys a screenshot from some video i took last night
http://www.polishdan.com/images/flower.bmp It was shot at night without any special lighting other then the lights on the ceiling in the room. P.S- does anyone know how to export a 16:9 movie in premiere pro so it does not display full screen but in widescreen? |
Sure...here ya go.
Of course, you will have to have started a widescreen project first, but I'm assuming you new that. 1. Move your work area bar over the area you want to export. http://www.extremesoundonline.com/forum/wsexport1.jpg 2. Select File - Export Movie. http://www.extremesoundonline.com/forum/wsexport2.jpg 3. Choose Settings http://www.extremesoundonline.com/forum/wsexport3.jpg 4. I use a Canopus DVstorm card, so your options may look different, but you should see something like this. Choose NTSC DV widescreen (1.2) under Pixel Aspect Ratio. http://www.extremesoundonline.com/forum/wsexport4.jpg Good luck! |
thanks a lot for the help
Welcome to DV-INFO, -gb- |
Hello Daniel,
You say screen shot, but how exactly did you produce it? Canon can take a "photo" but I never found it to be adequate, however your shot looks good enough to print! Good Job. I assume you were displaying it on your computer somehow and either hit print screen or had some screen capture software... but how did you do it? Thanks! |
-gb- |
Hey Greg,
thanks for the reply. I have an XL1 and an XL2, I thought that the XL1 had that feature, but I didn't like the results, so I never revisited it. I didn't know that they did away with it on the XL2 because I had no interest in it. So it sounds like the key may be in the high shutter speed and FPS setting. With my limited testing I would surmise that the shutter speed might be the more important factor. I only say that because I tried "Frame Mode" with the XL1 (it doesn't do 24p as you know) and didn't think the results were very good. I probably used 60th/sec shutter speed, which was probably way to slow for a still, but perfect for what I was shooting (the still photographer never showed up and I had to use frame exports for the artwork... not good). And whereas I would never try to get a video camera to act like a digital still, I think that Daniel's results were far superior to mine, and for a video camera, I could use that quality in a pinch with no problem. What say you Daniel? Greg, why do you prefer 30p over 24p, if I might ask? Thanks !! |
At the moment i like 30p over 24p just because it is less choppy. The screen grab i took was all on automatic settings the first day i got my camera. When i imported the footage into adobe premiere i just used file/export/frame feature and it automatically puts it into a bmp file. Mind you not all my footage showed up exactly as well as that i just chose a pic that stood out at me.
-gb- |
Gotcha... Thanks Guys !!
| All times are GMT -6. The time now is 04:42 AM. |
