Canon / Sony playback compatibility?!
Hello -
I have a bunch of Mini DV tapes that I shot with a XL1. To play back these tapes, I am using a Sony VX1000 and Sony PC9 …. as I no longer have the XL1. The issue I have is that some of the tapes play fine, while others have problems such as skipping/dropping frames. For tapes, I utilized Sony, TDK's, Panasonic, JVC brand tapes. My questions are: - Is this a Canon / Sony camera issue? - Is it a tape issue? If it's a CAMERA issue, then could I get any Canon Mini DV camcorder to play them back or would it have to be specifically an XL1? Any suggestions will be greatly appreciated!! |
Re: Canon / Sony playback compatibility?!
I"m almost sure it's a tape problem, don't you know anyone that still has a minidv camera or own a tape deck such as the Sony DHR-1000? Then you could test to know for sure, otherwise you might buy a camera and have the same problem.
MiniDV recordings should playback without problem if made at SP speed.
Do you see breaks in timecode or the scene at the skips, or are they mid-shot? Where the bad tapes shot at LP speed. (LP is not reliable if played on a different machine from the recorder). Where the skipping tapes shot during a different time period from the tapes that play OK, or are they interspersed? (Camcorders age and the tape path alignment can drift slightly over time.) Do the suspect tapes always skip a tthe same point on the tape, or does it move around? (If the skip point moves around, you can try recover by recapturing the skip area and then editing it in to replace the bad section.) If some tapes play well and other do not it is more likely a tape issue. By tape issue it could be physical/mechanical with the tape, or the actual recording on the tape. Is it more pronounced with audio or video? In some cases tape read errors may prevent firewire captured, but analog output may appear OK thanks to error correction in the playback machine's analog output circuits. In this case analog capture may provide a viable alternative. In any case, try a head cleaning. It might help if the issue is a weak read of the signal on tape. |
I'm located in the Bay Area, CA .... so if anybody would happen to know of a good, reliable local rental house, please advise; will much appreciate it!! |
Thanks Don, appreciate your time and input!! |
