-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   2 mics (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/48482-2-mics.html)
Joe Kramer July 28th, 2005 05:52 PM
2 mics
Hi,
I just recently bought two wireless lav mics, but have no experience whatsoever with microphones, so I apologize if these are really basic questions. I basically want to record with the two wireless lavs, without using the mic that comes with the XL2. I know I can attach one of the tuners with the shoe mount and plug it in to the front mic terminal (right?), but in order to attach the second, would I need to buy the MA-300 adapter and plug it into the back (and if so, would it be best to just plug both into the back?)? If this is the case, is there any good way to attach the second tuner to the camera, or would I just need to hold it?
My second question is, to use the two wireless lavs, would I record on 16bit? I wouldn't need channels 3 and 4, would I?
Any help would be appreciated. I guess I'm basically just asking what the simplest set-up to use would be. Please bear in mind that I have no experience with this and am very new to the XL2. Thanks a lot.
Matthew Wilson July 28th, 2005 06:55 PM
Hi Joe,
What kind of wireless mics are they? Some of the answers will depend on that, but in general, if you only need to record two channels, one for each mic, you want to connect the outputs to the rear XLR inputs of the XL2, one in channel one and the other into channel two. Record 16 bit. There is a a switch on the audio section behind the flip out door which allows you to choose the input source for channels 1 and 2 when in 16 bit mode. Just flip the input select switch down to "rear" and the channel switch down to "1 and 2." Depending upon your receivers, you should be able to set the optimum level at the wireless receiver with the XL2 channel volumes at about 11 o'clock for the best S/N. There is an attenuator switch at the back of the camera for each inpout as well as phantom power. You shouldn't need either (depending upon the mics of course). There is a black metal bracket that comes with teh XL2 that mounts via three screws to the rear of the camera. You can mount your wireless receivers to it with velcro etc... It's actually pretty handy.
regards,
Matt
Joe Kramer July 28th, 2005 08:19 PM
Thanks a lot for your help, Matt. You've made things way easier for me. I'm using Sony UWP-C1's; should this be a problem?
Matthew Wilson July 29th, 2005 02:42 PM
Those should work great - You can mount one on the shoe and the other on the rear of the camera. Let us know how they sound. they look like they could be pretty good mics.
Matt
