Trying to record on 2 channels with 2 sources
Recording a stage production in 2 wks. I want to record house audio using the on board mic and take a feed from the audio board to get clean music. BUT, you can't feed XLR's into back of camera and still use on board mic (flipping the switch to rear disables on board mic.). Do I need to purchase an audio matchbox to correct the audio levels (so I can feed XLRs into the converter and take out RCA's and feed those into side of camera? AND if I do all of that, what do I set my audio set up to : 16 bit, 12bit ch 1/2, or 12bit ch 1/2, 3/4. Manual is very unclear. Tech support didn't even know when I called them. Please help!
Hi Kathryn,
Set the camera to 12-bit 4-channel (that is, 12-bit ch 1/2, 3/4). This will enable you to use the onboard stereo mic (it requires two channels all to itself since it's stereo), and also at the same time you'll have both of the rear XLR jacks available as well. |
Canon says I need an audio matchbox
If I use the on-board mic, I can't use the rear XLR's because when you switch that little switch to rear, it cancels out the onboard microphone. Was wondering if I could plug a mic into one XLR and the line level out of the board into the other XLR, but Canon says that wouldn't work either.
Hi Kathryn,
Let me know if any of those steps aren't clear! Quote:
Hope this helps, |
Hi Chris:
The steps you outlined are much clearer than page 50 of the manual. I thought that there was an oversight when I read that the XLRs were for mic level and NOT line level. I did purchase an audio matchbox from B&H which converts balanced audio to unbalance (RCA's) and vice versa. I think that will help my situation. Tech support at Canon was lacking in the audio area. Thanks for your advice.
And, btw, what settings do you use when you shoot your recitals/plays -- how do you avoid allowing the aperature to open too much when you are fully zoomed out (and the lower 1/3 of the frame is black from the audience and the upper 1/3 is black from the top of the stage )--- AND the camera is trying to compensate by opening the iris and thereby blowing away the stage? Thanks again for your much needed, much appreciated help. |
Great info! Thanks Chris
Chris,
I had the exact same question. Thanks for saving me all the time that Kathryn had to spend before coming to you! You rock! Brian |
| All times are GMT -6. The time now is 09:22 PM. |
