red colour problem
I do have a problem about red colours when i shoot pictures whith my XL2.
The problem is the same every time. The red colours is much too red. It looks as the saturation on red is much to high. I always use the cinelook settings. 25p, Gamma, colourmatrix cine, black pressed witch gives me some very nice pictures. An example is our red Volvo 245 or a red danish mailbox. Even on a cloudy day they become much too red. I thought about adjusting the colour R-Gain in direction Cyan, havenīt tried this, but is it really nessesary to adjust the Colour Gain, it should be OK when the whitbalance is right? |
White Balance
You probably do this anyway, but I find that you can eliminate or reduce your reds by setting your White balance manually for every scene. I carry a small 8.5 by 11 sheet of white "plastic cardboard') take 2 seconds to set the balcance and you get much better color reproduction.
While the XL2 produces truer colors than the XL1s it still boosts the saturation of reds by almost 20%. About all you can do about this is reduce the saturation of the entire scene in post using primary color correction or reduce the saturation of the reds alone using secondary techniques.
You can change the complete look of the picture in this camera,
why not simply reduce the red levels if that is such a problem? And yes, you can futher finetune it in post. |
Thank You everybody.
I will try to play with the coloursettings. |
I'm thinking that if you simply reduce red gain it will shift everything else in the cyan direction i.e. a gray card or white fence will take on a cyan cast but it's worth trying. If I were going to tweak anything in the camera it would be the color gain. Reducing this will desaturate the red and everything else as well.
Well, Iīm a little embarrassed about this issue. I tried for hours to adjust the red colours, but I newer got any natural red colours. But after many hours I decided to create a DVD with some footage through Adobe Premiere Pro 1.5 and Adobe Encore. When Playing the disc on my DVD-player the colours looked much better. The problem was to find in the communication between the Camera and Premiere. I "just" have to find out how to adjust the settings in Premiere.
Anyhow thanks for Your adwise. I got some better colours, the reds are still a little to much in a pink direction compared with the natural reds which looks warmer. |
| All times are GMT -6. The time now is 10:26 PM. |
