-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   FU-1000 b/w viewfinder (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/38657-fu-1000-b-w-viewfinder.html)
Chris Staab July 22nd, 2004 05:19 PM
Fu-1000
Does anyone know whether or not the menu options and audio levels will be displayed in the existing FU-1000?? Please....someone have some good news for me. I just bought this viewfinder a short time ago.
Chris Hurd July 22nd, 2004 05:50 PM
Yes to everything, plus 16:9 is properly letterboxed. So you can rest easy.
Chris Staab July 23rd, 2004 12:56 AM
Great news!!
That's so good to hear. Now I can be fully excited about the XL2!! Take care.
Mark Grgurev August 17th, 2004 01:15 PM
FU-1000 not compatible with XL2
I was looking at accesories for the XL2 on canondv.com and apparently the Fu-1000 is NOT compatible
http://consumer.usa.canon.com/ir/controller?act=SNAModelSuppliesAct&fcategoryid=818&modelid=7471
Yi Fong Yu August 17th, 2004 01:40 PM
that's quite the surprise... so there is no hi-res viewfinder to pull nice focuses?
Jean-Philippe Archibald August 17th, 2004 01:49 PM
It's only an omission, the Fu-1000 is FULLY compatible with the Xl2.
Look in the features list. Near the end you can read "-Body compatible with FU-100 B/W EVF (not with current color EVF)"
You can also look at The watchdog's image gallery. The last pîcture show the dedicated connector for the Fu-1000, wich I believe, provide the 12v power required by the monochrome viewfinder. If I am correct, with the XL2 you don't have to put the adapter between the camera and the battery. A great addition!
EDIT: I just found this on the watchdog's FAQ in the compatibility list: "Q: Will the Canon FU-1000 monochrome CRT viewfinder work on the XL2?
A: Yes, it's perfectly compatible with the XL2; in fact, you no longer need to use the power adapter in the battery well. What's more, the monochrome CRT viewinder will display a properly letterboxed image when shooting in the 16:9 aspect ratio. "
Hope this help,
Mark Grgurev August 17th, 2004 02:01 PM
thanks Jean-Philippe
John Dovydenas November 14th, 2004 05:37 PM
FU-1000 plug standard?
I was wondering if any of you know if the connection plug on the FU-1000 is some sort of industry standard, or just a canon proprietary jack? I'm referring to the the plug physically connected to the unit, not the one on the XL1 voltage rectifier. I ask because I would like to get a high resolution color viewfinder, and Im wondering if there are any that would simply plug into the XL2? Alternately, does anyone know if there are any high resolution color viewfinders w/ a super video plug, which would be almost as good.
Some of you may suggest I use an external LCD screen. This wouldnt work (for me) as I need the viewfinder (sometimes) for focusing midshot and handheld. My desire for color is somewhat extravagant, as I could use a TV for color balancing, however, I'd like something compact and quick to set up, and espesially for it to be mobile and unencumbered. Plus color is an essential component of creating a composition; the FU-1000 is somewhat disorienting in this respect.
It also occurs to me that even if the plug is proprietary that I could fasion a dongle which would route the proper signals to the right wires. Does anyone know what kind of signal is being sent to the viewfinder? (component? some sort of composite medley?) Any feedback would be much appreciated.
Chris Hurd November 14th, 2004 05:43 PM
It's a composite video signal that's fed to the viewfinder, and yes, the EVF connections (for both the color LCD viewfinder and the monochrome CRT viewfinder) are proprietary Canon devices.
Christopher Go December 11th, 2004 08:49 AM
Canon XL2 & FU-1000 Viewfinder
I am thinking of purchasing the FU-1000. However, after reading Ken's excellent article on this device, I was wondering about the following as it applies to the newer XL2:
The second caveat is more noteworthy. After using the FU-1000 for a while you may suddenly notice that something’s missing from the EVF indicators: the battery level indicator. Apparently the FU-1000’s voltage adapter also confounds the battery level indicator until the battery is nearly depleted, at which point a flashing battery indicator will appear in the viewfinder. This can lend a new level of excitement to your shooting since the FU-1000’s 12w load will drain your battery quicker than the FU-500’s LCD viewfinder. So be sure to stock-up on charged batteries before a shoot and change them before shooting a long sequence. Even better, use the CH-910 dual battery holder.
Is this still an issue with Canon's latest camcorder? For anyone who has this setup, can you see the battery indicator in the FU-1000 viewfinder? Ken's article can be read here.
Richard Alvarez December 11th, 2004 09:53 AM
I just plugged mine in, and I can see a little battery indicator that shows about 1/3 of the batt empty.
David Lach December 11th, 2004 10:43 PM
This, I beleive, was only true when using the FU-1000 on the XL1, since it required a voltage adapter. This is no longer the case with the XL2, since the camera converts the needed voltage directly through its prioprietary viewfinder connection. I just finnished shooting my first day with this puppy and I can confirm I didn't get any problem of this nature with it.
I had to rent one for the shoot but I will certainly buy one as soon as I can afford it. What a difference. Resolution to burn and you see the whole frame. It's such a breeze to frame and focus. The first day of shooting of my current project I had to use the standard EVF and with all the complicated shots I had planed, it was close to a nightmarish experience. I will never shoot without the FU-1000 ever again. Worth every penny in my book.
Christopher Go December 12th, 2004 04:50 AM
Thanks for the help, Richard, David. I will definitely buy a FU-1000 viewfinder in the near future now that I know I won't have to worry about guessing how much power I have remaining.
Donald Pittelli January 31st, 2005 07:01 PM
just added fu1000 to my xl2 . now bare in mind the dirrections that come with it are for a xl1s . so you get this adaptor with it for the power supply . well geewiz it dont fit takes me 20 mins to figure out the xl2 dose not need power adaptor .anyway this b/w unit makes the color finder look like a toy . this thing is sharp easy to focus and has better detail than the color finder .i am very happy with it . any tips on this unit i should know about . thanks dp
Charles Papert January 31st, 2005 08:25 PM
Donald:
congrats on your purchase, it's a great piece of gear.
One thing to be careful about are the controls for brightness and contrast on the underside. These can easily be knocked, and if the brightness is all the way down it will appear that the viewfinder is off, and you will spend plenty of time trying to figure out why you don't have a picture. It may even be worth putting some tape over the brightness control once you have it dialed to your satisfaction to prevent this.
Donald Pittelli January 31st, 2005 08:44 PM
thanks Mr Papert
this thing has some nice features . i like the adjustment for the eyepease tention and the little spot lite .it adds some weight to the front though . dp
Chris Hurd February 1st, 2005 12:14 AM
Ken Tanaka's review is geared toward using it with the XL1S, but most of his article (except for the unnecessary power converter) applies to the XL2.
Mark Sasahara February 1st, 2005 02:03 AM
The lens light and tally on/off are handy too. The lens light was very helpful while shooting in a darkened studio. Just before my camera died. I'll post about that later. More Mark waaah, waaahing :~).
I'm left eyed, so I'm looking through the finder with my left eye and loking at my lens with my right eye. I put chart tape on my 16x manual lens focus ring, make my marks and rack focus back and forth as my subject moves around.
Sometimes it's good to turn the tally light off, so people don't know you're rolling. Be sure to cover the light on the back of the handle too.
Donald Pittelli February 1st, 2005 05:21 AM
thanks guys
thanks Mr Hurd and Mr Sasahara this viewfinder is easy to get fond of . i wish i would have seen Mr Tanakas review before i opened the box . it seems it should be easy enough to tape some added notes for the xl2 on the fu1000 box . but hay i figured it out anyway . thanks again dp
Richard Alvarez February 1st, 2005 08:47 AM
Yes, its a geat viewfinder. The color evf is nice for the 'waist level' shots, but I am definately spoiled by the sharpness and ease of viewing on the FU-1000. Charles is right about bumping the brightness nobs. I dissassemble the camera to pack it away, and twice I've bumped the brightness down to zero while reassembling it. Freaked me out.
Mark Sasahara February 1st, 2005 01:12 PM
Yeah, the first time I mounted the FU-1000 and tried to plug it into the XL2 was a comedy of errors. I almost freaked when it wouldn't fit in the socket. Blind boy finally realized that there was a second port. Sigh of relief.
The power converter thing. Heh, I think the cord was too short or something. I got very frustrated and then after about ten minutes, I figured out I didn't need it. Another sigh of relief.
It would be nice if they tossed a peice of paper in the box with notes for plugging into the XL2. Save people a lot of aggravation.
Does anyone from Canon read this stuff? I know Jan Crittenden from Panasonic is a regular-she totally kicks ass.
Donald Pittelli February 2nd, 2005 04:27 AM
thanks again
i am sure theese tips will help . i was reading other thread on the master fuse thing .sure hope this view finder is not the problem . now i dont come close to the amount of use you guys do . maybe 3-4 hours a weak . well thanks dp
Mike Bluestone March 15th, 2005 09:56 AM
fu-1000 power consumption
Anybody know if the fu-1000 and XL2 combination is better than the XL1S for power consumption. Someone suggested to me that on the XL2, it uses only a little more power than the color viewfinder. I find that hard to believe, but maybe????
Chris Hurd March 16th, 2005 12:37 AM
See http://www.dvinfo.net/canonxl2/articles/article09.php
Mike Bluestone March 16th, 2005 02:52 AM
Thank you for pointing that article out to me
Bruce S. Yarock June 3rd, 2005 11:40 AM
Monochrome viewfinder problem
I mistakenly posted in the xl1 forum, so excsue the cross post. I got my fu-1000 today, and I really like it. I was unable to hook up the power adaptor, but was able to run it with my Anton Bauer. I called Canon, and the guy in customer service told me that the adaptor just slides in. I can't get it to attach.
has anyone else had this problem?
Bruce S. Yarock
Bruce S. Yarock June 3rd, 2005 11:56 AM
I just tried a Canon battery without the adaptor and IT WORKS!!! This viewfinder is beautifull...I can really see what I'm trying to focus. So the when using the fu-1000 on the XL2 (as opposed to the xl1/s), you don't need the battery adaptor, and the viewfinder shows battey usage. I love it.
Bruce Yarock
Richard Alvarez June 3rd, 2005 12:59 PM
Bruce,
That is correct. When using the viewfinder on the XL2 you simply plug it into the monochrome port, instead of the color port. There is no need for the adapter to go into the battery well.
It is a great viewfinder, isn't it? Nice and sharp.
Chris Hurd June 3rd, 2005 01:36 PM
Just to be clear, the power adapter is NOT NEEDED when using this viewfinder with the XL2.
Bruce S. Yarock June 3rd, 2005 06:39 PM
Richard,
Thanks again for the info. I love this thing, and I know it's gonna make focusing much easier. I tried calibrating it following Ken Tanaka's article, but I'm not sure if I got it right. Any suggestions?
Chris,
That sure is nice that the adaptor isn't needed, and also that the viewfinder shows battery usage.
Anyone need a spare battery adaptor.....?
Bruce Yarock
Mark Sasahara June 3rd, 2005 09:11 PM
Enjoy. Be sure to turn the power off when you insert, or remove the plug for the B&W viewfinder. Apparently doing that while the power is on can weaken the fuse or blow it altogether. Mine died in the middle of a job a month or so after installing the FU-1000. Be careful.
To facilitate accurate focusing, crank the peaking adjustment so there is a bit of a white edge. You'll see things in focus a bit more clearly. A handy trick.
Bruce S. Yarock June 3rd, 2005 10:09 PM
mark,
thanks for the tip on the "peaking".I'm still not sure about the calibrating. I followed the instructions in Ken Tanaka's article, but I'm not sure if it's correctly done. Any tips?
Bruce yarock
Mark Sasahara June 3rd, 2005 11:02 PM
Not sure, haven't seen the article. I'll check it out. I'm s'posed to be in bed, big job tomorrow.
-M
Bruce S. Yarock June 4th, 2005 04:49 AM
Mark,
here'sthe article.
http://www.dvinfo.net/canon/articles/article83.php
Bruce yarock
Mark Sasahara June 4th, 2005 06:38 PM
Bruce, Thanks. Much appreciated. There are a few things that are different for the XL2, but good info.
TA
Per Johan Naesje July 15th, 2005 02:54 PM
Fu-1000 viewfinder
Are there any difference between a PAL and NTSC camcorder using this viewfinder or will it fit on both?
- Per Johan
Rainer Hoffmann July 16th, 2005 04:42 AM
Per,
try to search the XL1 forum. I remember a thread were someone from the UK had got the FU-1000 from the US. If I remember correctly there was a way to connect the NTSC version to a PAL camera. It required some modification that might void the warranty, though.
Declan Smith August 20th, 2005 04:32 PM
FU-1000 & XL2 16:9
I am thinking of getting the FU-1000 for my XL2. Can anyone tell me if it displays the 16:9 aspect ration when the canon is set to 16:9 or is it squeezed ?
Chris Hurd August 20th, 2005 08:39 PM
Hi Declan, it displays letterboxed 16:9.
Robert Luke August 20th, 2005 10:39 PM
what is this FU-1000 or whatever it is that you speak of.
