-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   A1, 24F, Aspect, & PPro 2 (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/99946-a1-24f-aspect-ppro-2-a.html)
Dearl Golden July 27th, 2007 08:08 PM
I've searched throught the appropriate forums, but can't find a definitive answer to this, so......
Planning to shoot my first 24f tomorrow with the A1 and I'll be capturing/editing with Aspect 5 and Premiere Pro 2. I'll be downloading the Adobe update to allow editing in this mode.
I've set shutter at 1/48.
My confusion at this point is which "pulldown" should I use?
Thanks in advance for a simple, clear answer.
Pete Bauer July 27th, 2007 08:15 PM
Hi Dearl,
No pulldown at all is required. I'm not using Aspect 5, but should be straightforward. The 24F goes to tape as 23.976 progressive frames per second and will be captured using PPro2 or later and Aspect. Should be no fuss, no muss once you have the camera set and the software installed.
Dearl Golden July 27th, 2007 08:23 PM
Thank you, Pete.
