the 21 minute tape problem
I shot a documentary last weekend and I shot on one digital Master tape... and the rest were mini dv. This was only because I had one DM tape and couldn't find a local source for them as I was on a very tight timeframe. When capturing the DM, I got the whole 63 minutes into Premiere Pro 2. I was very busy so I just captured all of the tapes (or so I thought). The mini dv's appeared to be capturing the entire length of the tape - but when I went back in to check, they stopped capturing at 21 minutes - EVERY TIME, every tape. Has anyone had this happen? I managed to get all the footage I needed by doing it in 20 minute intervals. I'll certainly not make the mistake of using mini dv tapes in my A1 again. just thought it was weird.
Thanks |
File system
Hi Keith,
might it be possible that you have a FAT32 file system on your hard drive where you have captured the mini DV tapes? The maximum file size for FAT32 is 4 GB. This could explain the 21 minutes time limit. Maybe you have captured the DM tape on a NTFS hard drive. Axel |
I wish it were that simple to explain Axel... all tapes went to the same drive... it's a relatively fresh separate drive and I still have appx 250gb left on it... I've captured other DM tapes no prob.
Keith... 1st of all "miniDV" is just the tape form factor & nothing else. The Digital Mastering tape you refer to is STILL miniDV. With that out of the way... your problem is something else entirely & Axel's thoughts do make more sense than it being a DM vs. non-DM matter.
Bill |
I'm still using the same mini dv tapes in my A1 as I've used in the past in my SD panasonic GS400 recorder.
Never had a problem. No dropouts, no dramas. |
