-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Decent on-camera monitor (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/98835-decent-camera-monitor.html)
Nick Csakany July 12th, 2007 07:37 PM
Hello all,
I am looking to add an on-camera monitor to my XH A1, so as to better help me in nailing manual focus. I looked at the Glidecam and VariZoom models, and also searched these forums, but being a noob I feel like I need some directions. Is there any one model you are particular towards? Also, do they work off rechargeable or AA batteries, or would an external battery pack be required for field recording, where no A/C adapter would be readily available?
Thanks in advance,
Nick
John B. Nelson July 12th, 2007 08:19 PM
Beleive it or not.. right now I'm using a portable Poloraid DVD player as an external monitor for the A1. It has a 9 inch screen which makes focusing on a subject really easy. The battery lasts for 3 or 4 hours before it needs to be charged. I am in the process in trying to rig some kind of stand for it.. maybe by using a tripod or something... I'll figure something out hopefully. Anyway, thats what I'm using and its working great.
-John
Chris Barcellos July 12th, 2007 08:25 PM
I'm using a Polaroid 7 in DVD player bought for $100 at Walmart, for same purpose. It is not HD, obviously, but it also flips when I use it with my Letus Adapter...
Joseph Hutson July 12th, 2007 08:30 PM
Southern engineering eh?
ha
That IS a pretty good idea. But how do you mount it?
Joseph
Dennis Murphy July 12th, 2007 08:48 PM
Buy it a couple of drinks and tell it that it has beautiful eyes.
Sorry, the devil made me do it.
Jeremy Naus July 13th, 2007 02:12 AM
good to hear that those DVD players are usefull as external monitor.
I'm thinking of getting myself one after I made my own Stabilizer (got Cody's plans) and/or crane.
What type of cable do you use to connect it to the XHA1?
Nick Csakany July 13th, 2007 07:31 AM
I think most DVD players would connect via the composite A/V, and not component. It would also be kind of awkward using the bulky component cable for such a short distance.
I'll try to figure out how to mount one of these DVD players, but I'm still looking at a proper external monitor.
Thanks for all your input. This is a great place to be, and I cannot begin to express the amount of knowledge that I absorbed while lurking in the background!
Nick
James Binder July 13th, 2007 10:54 AM
Here's the one I use. Not HD, not great resolution, but very good if your prefer to see a MUCH larger image than the onboard LCD.
Varizoom VZ-TFT7U 7-Inch Widescreen Color LCD
http://www.bhphotovideo.com/c/produc...D_Monitor.html
Chris Barcellos July 13th, 2007 11:45 AM
Nick
Heres how I used my with my HV20, and Letus. Velcro on bottom of battery, with velcro on bars on cross pieces. In this configuration it was wobbly because I also had cross bars velcroed. But I since did a new build on the flip arrangement, and bolted the bars on for a much steadier mount.
http://www.dvinfo.net/conf/attachmen...5&d=1182318059
Nick Csakany July 13th, 2007 12:22 PM
This is the one I was looking at. The kit, actually, which includes the mount, sun box, battery, and carrying case.
Does it impact the balance of the camera? I don't recall offhand if the hot shoe is directly over the tripot mount, of further towards the front. The camera already is front-heavy as is.
Nick
Nick Csakany July 13th, 2007 12:25 PM
Interesting. The camera almost gets lost in the setup. I guess the HV20 doesn't have a flip function, that's why you mounted it upside down for the straight Letus?
Nick
Henry Cho July 13th, 2007 01:29 PM
unfortunately, none of these monitors are appropriate for critical focusing. you need a monitor capable of displaying at least 480 lines of true vertical resolution. the least expensive of these hd lcd monitors currently available are the ikan 8000 hd, the varizoom swit, and the marshall. these other monitors may be fine for framing and work perfectly well for standard def, but focusing with them for high def would be a complete gamble. you'd be better off using the xha1's onboard lcd/evf and focus assist functions.
http://www.dvinfo.net/conf/forumdisplay.php?f=112
Chris Barcellos July 14th, 2007 05:42 PM
Nick
No flip function readily accessable , though you can open it up and actually install your own. However, I shoot upside down so when I capture the footage does not need to be flipped.
Chris Barcellos July 14th, 2007 05:44 PM
I agree, Henry. In the film I shot with this set up, I managed to hit it pretty close, and since it was going to SD, there was a bit less issue. But I don't mind telling you that before I saw the footage, I was a bit nervouse about the critical focus issues.
Nick Csakany July 14th, 2007 08:10 PM
Thanks all for the very informative input. Since I need an external monitor primarily for checking and attaining focus -- as opposed to framing -- I guess the way to go is HD. I'm looking at the Marshall and Nebtek products right now, and will probably make a purchase this week.
